Old 7/27/11, 4:01 PM
Tim C. Howell Tim C. Howell is offline
Default Geothermal
Have an inspection coming up where the home is heated / cooled with goethermal. Any tips or suggestions on what to be looking for? Or where to find some information on inspecting these systems.
Thanks everyone,
Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/27/11, 5:38 PM
RAY THOROMAN RAY THOROMAN is offline
Default Re: Geothermal
Make sure you stay within the SoP or state licensing SoP. Disclose or report on what you can't see.
http://en.wikipedia.org/wiki/Geothermal_heat_pump
Old 7/27/11, 6:02 PM
Michael R. Boyett's Avatar
Assuming you have a ground or water source heat pump then this might be pertinent. It is from a post about a home I did last Sept:
The 2 year old home I inspected last Friday had 2 ground source heat pumps. I had an independent 3rd party service provider (Stan’s A/C) inspect them for me and American GeoThermal, the original system installer, was there as well to describe the systems and answer questions.
Each unit was a ‘packaged system”, i.e. the water pumps, exchanger, compressor, evaporator coil were all in one enclosure in the attic.
  • These particular systems essentially trade the condensing unit fin system (that would be an air-source heat pump) for polypropylene looped tubing buried 300’.
  • One 600’ loop (300’ down, 300’ back up) handles ~one ton of A/C and there was a total of 7 tons at this house therefore 7 down holes.
  • I think the tubing was 1.5” but I’m not positive of that, it’s all buried and nothing is visible above ground (strange to see a home like this with no condensing units outside).
  • The tubing holds water w/ anti-freeze and is pressurized to around 12 psi (Stan’s tech said they pressurize to 65psi but I don’t know the pros/cons of such).
  • The package unit in the attic has a compressor with a small amount of refrigerant, maybe 12-16 oz they said. Therefore neither Stan's nor the original installer recommended putting gauges on the refrigerant so as to not risk losing any.
  • Both companies said the use of temp splits was acceptable and the systems would compare to deltas of a regular a/c system but maybe a degree or two higher. One of them quoted 15-24 degree splits could be expected.
  • The tech did check circulating water temp and pressure and splits on both systems….$150 ea system.
  • Even after being assured by the Builder/Seller/Occupant and the original installer that the systems were running perfectly the Stan’s tech did find very low water pressure on one system and low delta-T on the other so the client’s money was well spent. It didn’t appear anything significant was wrong, the systems just needed ‘tuned up’.
  • The Seller said his August electric bill on this 4,100 sf two-story home was $150 (I didn’t see the bill however). Avg daytime temp ~97° probably.
I learned a little about geothermal but it was so hectic at this inspection that I wasn’t able to learn nearly as much as I wanted to.
Old 7/28/11, 10:08 AM
John M. Acaron's Avatar
John M. Acaron John M. Acaron is offline
Check for:
Source of water (quality)
Pressure
Filter
Type of system (open loop, closed loop,...
Check Temp at each water furnace (Thermostat/register)
http://www.geothermal-heat-pump-resource.org/
John M. Acaron, BSME, CMI
HOMEINSPECTORUSA, LLC
State of Florida Licensed Home Inspector
State of Florida Licensed Mold Assessor
BSME & TDME (Mechanical Engineer)
Certified Master Home Inspector
Certified Indoor Air Consultant
Office: 850-814-3889
FAX: 850-249-8997
SEMPER FI
Old 7/28/11, 11:09 AM
Robert J. OConnor's Avatar
You can easily get overwhelmed inspecting some of these systems. Keep it simple on a home inspection.
It's very similar to inspecting a standard air source heat pump (packaged or split), except water is pumped through the ground to heat/cool the refrigerant instead of using outdoor air drawn thru a unit with a fan to heat/cool the refrigerant.
And make sure to note the limitations of your inspections and parts of the system (e.g. ground loop) thats not visible for inspection.
JMO & 2-Nickels ...
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 7/28/11, 5:24 PM
David A. Andersen's Avatar
Don't do any of this BS!
Do your job like any other inspection. Observe and report!
90% of the HVAC guys can't do geothermal, so why do you want to join the ranks of the unknowing and get your business in a bind for something you are not required to assess?
BPI# 5015804
Old 7/28/11, 5:55 PM
Doug Edwards's Avatar
Ditto! Operate the system using normal operating controls, report what you see, move along.
- John Stuart Mill
Need to know???? cbottger Canadian Inspectors 1279 4/30/10 5:31 PM
Geothermal Training Course in Northeast Pennsylvania Brian Oram Inspection Education & Training 0 3/4/10 11:28 PM
Anyone know much about geothermal? rlondon Inspecting HVAC Systems 2 10/5/09 10:53 PM
Geothermal HVAC inspection jacaron Inspecting HVAC Systems 3 10/17/08 11:46 AM
Geothermal heating jcote Inspecting HVAC Systems 18 10/8/08 8:40 PM
