Old 6/23/09, 6:48 PM
Douglas Cossar's Avatar
Douglas Cossar Douglas Cossar is offline
Default Geothermal heating/cooling
Anyone know what to look for in a geothermal system.
I have an inspection on Thursday. Home has one
Thanks
Doug Cossar CMI, NHI
Accurate Home Inspection
Services Inc.
Whitby Ontario
www.accuratehomeinspections.ca
05021384
Find an InterNACHI certified Washington Home Inspector (and anywhere else in North America)
Old 6/23/09, 7:11 PM
Michael Larson's Avatar
Default Re: Geothermal heating/cooling
Thanks
Are you prepared to inspect something like this?
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 6/23/09, 9:42 PM
Doug Edwards,  CMI's Avatar
Read this: http://www.hvac-for-beginners.com/geothermal.html
and don't look for an outdoor unit...there isn't one. If you follow the SOP it should be little difference than checking any other HVAC system. Thank God not all of them look like the one in the photo. Just be honest and if necessary get the owner to show you the system and how it works using normal operating controls. I have seen some over the years and they look pretty much like any other system except often larger, might be some zone controls, etc. It is not exactly the Space Shuttle so do not let that intimidate you. You will be fine.
- John Stuart Mill
Old 6/24/09, 6:46 AM
Thanks for the link, Doug
I am familiar with the concept and understand how the systems work, however I have never seen one in real life.
Just wondered if anyone knows what to look for as far as problems go, aside from water/antifreeze leaks.
As suggested, my first thought was to use the normal operating controls to see if it functions and suggest to the client that he/she seek further info from the owner or a specialist as to regular maintanance etc.
Mike
Thanks for the photo
Cheers
Services Inc.
Whitby Ontario
05021384
Old 6/24/09, 9:12 AM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is online now
I dont know too much about them, but I will share what I know. There are 2 basic types, a closed loop system and an open loop system. (called a pump and dump) A closed loop recirculates the same water through an underground loop where the water is "heated" and brought back, and heat is exchanged. This is the the more efficient, preferred and far more expensive choice. The Second, pumps water from a 4-5 in well, (or a series of wells sometimes) and exchanges the heat and dumps it in its own drainfield. One of my clients told me that his system (I think it was a pump and dump) costs him an extra 30 bucks a month to keep his heat on low all winter while he is in Florida. The initail install is staggering, however.
Old 6/24/09, 9:25 AM
Annual service is recommended.
Here is more info:
http://www.nachi.org/forum/f20/geoth...heating-14874/
Larry Kage, CMI
231 929 3525
Old 6/24/09, 9:44 AM
Thanks for the input guys
Cheers
Services Inc.
Whitby Ontario
05021384
Old 6/24/09, 11:30 AM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Where are the normal operating controls?
Old 6/24/09, 11:40 AM
On the wall.
In this part of the country most of the ones I see are as complicated as the one in my photo and even more so.
I recommend annual service by a a tech familiar with these systems.
The cost of installation is huge.
Michael Larson
Hudson, WI
InspectraPro
and
Old 6/24/09, 11:45 AM
rmaday's Avatar
On the wall.
Understood, Mike.
I only verify operation as I would for a air heat pump system and recommend servicing annually by someone who is qualified to service these systems.
Need to know???? cbottger Canadian Inspectors 1279 4/30/10 6:31 PM
Geothermal HVAC inspection jacaron Inspecting HVAC Systems 3 10/17/08 12:46 PM
Age estimates for heating/cooling systems? bforeman Inspecting HVAC Systems 3 2/12/08 3:19 PM
Geothermal Heating system csteele Inspecting HVAC Systems 3 7/17/07 6:31 PM
Geothermal Heat pump wwarner Inspecting HVAC Systems 0 9/12/06 4:31 PM
