Old 10/9/08, 7:46 AM
John M. Acaron's Avatar
John M. Acaron John M. Acaron is offline
Question Geothermal HVAC inspection
Geothermal HVAC Inpection
Any info/details in inspecting a HVAC new (200 Geothermal unit (Closed loop).
Have anyone conducted an inspection in Florida? Feeback is ppreciated.
Thanks!
Old 10/9/08, 8:24 AM
Default Re: Geothermal HVAC inspection
Thanks!
The "search" function above brought these:
http://www.nachi.org/forum/search-1236934.html
Larry Kage, CMI
231 929 3525
Old 10/9/08, 9:06 AM
David A. Andersen's Avatar
, if you're familiar with heat pumps, whatever you do to test them do the same thing with geothermal.
There is no auxiliary heat to test.
Turn it on and listen for any funny noises.
Look for any sign of water leaks.
And of utmost importance, you should never see frost! Water circulation is generally the largest problem you will encounter. Reduced water flow will cause excessively cold suction refrigerant lines or frost.
Basically it's like a furnace. Turn it on and if it makes hot or cold air you'll have to assume things are working.
No one should expect a home inspector to evaluate a geothermal HVAC system. As Michael mentioned, you have a hard enough time finding an HVAC contractor to evaluate one.
If you find something odd, post it here and we will try to help.
BPI# 5015804
Old 10/17/08, 12:46 PM
It has been 15+yrs since being active in "the HVAC business", but we always provided in line electric auxillary duct heaters for emergency use, should the compressor shut down for any reason, or water circulation became a problem.
I'd look for aux.strip htr's somewhere within the system. If none found, I'd recommend the system be inspected by a Prof. HVAC Contr., and recommend to my client to request a quote to add this "apparent" option.
Just seems logical to me to be prepared for the likely reality.
Need to know???? cbottger Canadian Inspectors 1279 4/30/10 6:31 PM
what to report on old hvac equipment bking Inspecting HVAC Systems 8 7/6/08 5:10 PM
Room size requirement for HVAC supply kweiss Inspecting HVAC Systems 3 6/9/07 7:58 PM
Access to Electrical Panel in Ontario by HVAC Contractors Nalliah Thayabharan Canadian Inspectors 8 5/21/07 4:01 PM
Condemned Furnaces Spark Safety Issues Gary Reecher Inspecting HVAC Systems 7 3/8/07 9:17 PM
