Old 1/22/12, 9:33 AM
John Shetsky John Shetsky is offline
Please Note: John Shetsky is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Geothermal Inspection?
Has anyone inspected a Geothermal system? Just wondering what to look for on the system. I know it was installed in 04. Thanks, John
Need a home inspection in North Carolina? Check out InterNACHI's listing of North Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/22/12, 10:24 AM
Michael Larson's Avatar
Default Re: Geothermal Inspection?
See that it responds to normal controls just like any other system and recommend that it be serviced periodically by a reputable tech knowledgeable about this type of system.(most are not)
Michael Larson
Hudson, WI
Old 1/22/12, 2:01 PM
Joseph Hagarty,  CMI's Avatar
Same as a heat pump
Check the plumbing connections and pumps.
Many are also connected to a water heater so check those connections as well
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 1/22/12, 5:11 PM
James H. Bushart's Avatar
Geothermal systems include above ground mechanical devices and below ground systems that could be leaking glycol, be of insufficient depth, can be too close to drinking water wells and other factors that you are not able to observe or remark upon. Be careful not to declare any geothermal system as being "okay" simply because the mechanical equipment operates as it should.
Since most geothermal systems are not a part of the original construction, urge your client to conduct a permit search to ensure that it was properly installed by a qualified contractor and to inquire as to what, if any, warranties are in effect that could be transferred with the deed.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 1/22/12, 5:54 PM
Brian E. Kelly's Avatar
Look for obvious leaks and as mentioned above check it's normal operating conditions.
It would also be prudent to recommend review of all service records and recommend a service if the records are non existent or old.
Guessing as to the Refrigerant used in the System would not be prudent, IMO.
Old 1/23/12, 12:38 AM
David A. Andersen's Avatar
Do you want to put your name on something you know nothing about?
If the clients want it checked, hire an HVAC contractor.
Try to be there and you may learn something.
BPI# 5015804
Old 1/23/12, 8:40 AM
Bobby Hamilton's Avatar
Bobby Hamilton Bobby Hamilton is offline
That's the best advice
Bobby Hamilton
Bloodhound Home Inspection Services
Youngstown Home Inspection
Austintown Ohio Home Inspection
Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
Need to know???? cbottger Canadian Inspectors 1279 4/30/10 5:31 PM
Geothermal Training Course in Northeast Pennsylvania Brian Oram Inspection Education & Training 0 3/4/10 11:28 PM
Geothermal HVAC inspection jacaron Inspecting HVAC Systems 3 10/17/08 11:46 AM
Geothermal heating jcote Inspecting HVAC Systems 18 10/8/08 8:40 PM
Geothermal Heating system csteele Inspecting HVAC Systems 4 7/17/07 5:31 PM
