This was in a home built in 2003 in Lake Worth, Fl.
It is a fresh air intake from the exterior into the intake line which is in the garage. |
| Need a home inspection in Oklahoma? Check out InterNACHI's listing of Oklahoma certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Seems like a make shift Radon mitigation system.
Comprehensive Building Consultants Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection. Donate here: or send checks to the Fl Home and Insurance Inspector Chapter 1103 W Hibiscus Blvd Ste 311 Melbourne, Fl 32901
Could it be for a HRV(Heat recovery ventilator) or ERV (energy recovery ventilator)?
Is this a Cat 4 furnace and do you have any pics showing the other end?
We don't have Cat 4 furnaces here in S Florida...hell 1/2 the houses don't have ANY type of heat.
Well he did say air intake and this is the HVAC section.
Maybe he meant makeup air to closet. |
It is an electric, 3 ton split system air conditioning unit.
The line is, as you can see, metal and not insulated. The box, which is above the soffit, goes to a vent outside. The homeowner stated that this was a new requirement when the home was built. It is for make-up air that runs through the attic, down through the garage ceiling , and into the return plenum, which attaches to the stand the air handler sits on and then goes through the ceiling and connects with the other return registers in the bedrooms. There is also a damper right where the line connects to the plenum. I am assuming that the box pictured is some type of filter so that unwanted odors do not enter the home. I couldn't tell if condensation was building up which caused the sheathing to rot, or if it was from a roof leak. If the hot air from the outside can get in, what is to prevent the cold air from the home to get out? |
Don't assume anything the box pictured probably has no filter just a square transition from the round duct to allow a square grill in the soffit. All duct work associated with the central systems are required to be insulated in non-conditioned spaces such as attics. You last question tells me that HVAC is not your high suit and that you do not understand the system as a whole. I am not trying to be nasty here but some good advice would be to do some serious reading on the subject Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
I thank you for your reply, most of it. I am posting this because it is something I haven't seen in 22 years of performing inspections. Trust me, I am well aware of how the system works. I am also well aware of the code requirement for insulation (R-4.2) in an enclosed attached garage, which is where this line is located. I sent that along with another code reference Quote:
If you have anything, constructive to add, please do so. |
I don't know if it is constructive or not but I REALLY STRUGGLE with the last question you posted as to your understanding of the system as a whole. Nuff said As to make up air of course it is allowed from the exterior of the home just restricted as to where it can be taken from. Normally not required as 10% of make up air into a home is obtained through doors and windows Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
The fresh air intake line goes from this box, in the garage, through the garage ceiling, and this is the line that exits the building through the box shown. So, when the system is off, what is to prevent the air that is in the rooms, to go through the duct work for make up air and then out of the home? I will be gracious enough to assume that you meant that I was referring to air in the system, going backwards, through the cooling coils and then out of the building. That may be possible, but highly unlikely. It wasn't what I was referring to with the comment you are referring to. As to a filter, what I was referring to was some type of odor arrestor. Where the vent is happens to be on the side of the home where an ally is. Which is where all of the others place their garbage for pick up. There is also a neighbors house right near the vent. Unwanted odors may enter the home. Although this may be required by the code, and I have a call in to the building department regarding the installation, I wouldn't want it in my home. |
Correct me if I misread something but it appears the original post is all about a portion of the return air being drawn in from the exterior.
This is typical on energy star homes or homes built with attempted energy saving methods. Research is being done to change the standards since the big savings are not being achieved so far. http://www.google.com/url?sa=t&sourc...DE9a0gQrI7jzOA http://www.greenbuildingadvisor.com/...ort/html/13663 http://en.wikipedia.org/wiki/Ventilation_(architecture) B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
why is it that I'm getting the inclination that you're talking out your ***! ?
If you knew what you're talking about you wouldn't be posting the question. We all know what this is, you obviously don't. Who assigned you to be in charge over the authority having jurisdiction (AHJ)in Florida? I can only surmise that you played with HVAC equipment for a portion of your life. If that chunk of metal pipe you showed us from the attic enters into the garage, I'd be more concerned about it not being fire rated! Go ahead and call the AHJ and show them just how stupid the rest of us are. Thanks Quote:
It appears that you're making some sort of assumption without any documented testing results. What is the pressure differential of the building? Where is the neutral plane within the building? With this type of system installed it will generally create positive pressure in the building (in most circumstances). What is the pressure of the building? Or did you actually evaluate that? You ask us to evaluate which you have not evaluated. We cannot give you a definitive answer unless you provide the necessary data. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
