Single wall H2O Heater vent connector. Does NOT pass through the real wall, but does pass through a single sheet of dry wall ("A" side in picture) beside the real wall ("B".) Obviously NOT 6 inches of clearance. The wood stud is protected by a piece of dry wall (arrows.) Adequate heat shield? Combustible? ( this makes it fun: http://www.rumford.com/drywall.html ) Good or bad install? Tell me what you think, because I can't find the answer!
It's snowing in Denver... Tom Yeager Owner/Certified Inspector Inspect-It 1st 303-464-9090 www.tyeagerinspects.com NEHA Radon Certification # 104169 RT NACHI Certified Home Inspector |
| Find an InterNACHI certified District Of Columbia Home Inspector (and anywhere else in North America) |
arook is a non-member guest and is in no way affiliated with InterNACHI or its members.
I would write it up as a lack of clearance to combustible material.
To close , refer it to a qualified contractor.
It's wrong, and needs to be corrected.
In these situations, I usually suggest replacement with a B-vent as a simple and reasonable solution. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
What Jeff says B vent only requires 1 inch clearance to combustables
That's what i thought, just seeing if anyone would support my client's theory that drywall is not combustible and is acting as an adequate heat shield over the wood. I know, I know, never let a client talk you out of what you know is wrong! But he king of had me going... Thanks ya'll!!!!
Yup, no reason for sgl wall to pass through a wall...
| Deere John: It's Been A Good Ride | jburkeson1 | Miscellaneous Discussion for Inspectors | 1 | 7/19/08 12:29 PM |
| OAHI Out Of Control - Bylaws Breached - Documented Proof | rwand1 | Canadian Inspectors | 423 | 2/25/08 6:20 PM |
| Vinyl Siding Install | psmothers | Exterior Inspections | 3 | 4/21/06 2:44 PM |
