Anyone know age and btu's?
Goodman Electric Either A36-15 or 835-15. Doesn't show up in Prestons. Thanks |
Goodman First two digits of the serial number are the year. Second two are the month.
Btu rating is model number...i.e.; GMP075-3 (75,000 bonnet input) Compressor is same: serial # 9709088872 (yr1997 wk 09) Tonnage is model # CK361C The first two numbers after the CK (letters) divided by 12 is tons. i.e.: 36 div by 12= 3 tons. So based on this info, I would say it's either 36000 or 35000 btu. That seems very small. I didn't know they made them that small. You sure this isn't an air conditioning unit? 3 Tons? Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
A36 would be a 3 ton Goodman air handler.
You would need to determine the KW of the strip heaters. Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
| Furnace Problem Comments Welcome | rfrost | Inspecting HVAC Systems | 24 | 10/21/07 7:26 PM |
| Sweating decision:Settle for lower SEER to use existing furnace? | Fel Randolph | Inspecting HVAC Systems | 2 | 6/6/07 3:56 PM |
| Armstrong Ultra 80 Oil Forced air furnace | Stephen Frazer | Inspecting HVAC Systems | 19 | 4/9/07 9:00 PM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 9:17 PM |
| Goodman Furnace | csteele | Inspecting HVAC Systems | 4 | 11/10/06 10:07 PM |
