mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
Any issue with return grill on return plenum? I know it is not allowed for combustible furnaces. This is interior of condensor/evaporator for heat pump. I am thinking that if this grille is open it will not pull as much air from the return grilles through-out the home.
[quote=mnicholet;430716]Any issue with return grill on return plenum? I know it is not allowed for combustible furnaces. This is interior of condensor/evaporator for heat pump. I am thinking that if this grille is open it will not pull as much air from the return grilles through-out the home.[/quote]
Your thinking would be correct the blower will draw from the path of least resistance. It appears to me that the furnace is located in a basement is this correct. Most every basement That I know of has a musty smell that I would not want distribuited through out my home. If there are no gas combustibles appliances within ten feet of the furnace one cannot get into a code fight over this. Its just a dumb install IMHO Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
[quote=cbottger;430749]
The red is a US requirement. It is a dumb location for a return grille unless they are trying to use the AC (if it is a reversing HP/AC) for summer basment/crawlspace dehumidification. Depending on summer conditions and the amount of AC needed in your area, it may be better/cheaper to use a dehumidifier in an unfinished crawlspace. |
[quote=Brian A. MacNeish;430874]
Brian, Wouldn't adding a dehumidifier in this situation result in more energy being used as opposed to having a *Reversing/HP/AC* unit properly balanced. My thoughts only, Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
[quote=mgratton;430936]
Just lost 3 paragraphs to cyberspace on why I think the dehumidifier was the better choice in this crawlspace situation. In general, it may or may not cost a bit more but IMO, it will do a better job as a dedicated unit than the general HP/AC system. |
| grille on supply plenum | mnicholet | Inspecting HVAC Systems | 4 | 6/18/08 5:28 PM |
| Nice return air plenum EXCEPT | cbottger | Inspecting HVAC Systems | 4 | 5/15/07 9:50 AM |
| Supply Plenum Mounted High in Attic | Skip Erwin | Inspecting HVAC Systems | 6 | 4/7/07 11:07 AM |
| Freon lines in return air plenum | jlybolt69 | Inspecting HVAC Systems | 13 | 3/16/06 8:56 AM |
