From today's inspection. 2 story residence, built in 1997, both the Master bath and Hallway bath exhaust vent hoses terminate into the attic floor structure. As you can see, hose is foamed in place, the only exterior vent ports are the dryer and microwave. New one on me, can someone explain?
Thanks Andrew MacDonald MacDonaldPropertyInspections.com InsightThermalDiagnostics.com ITC/FLIR Certified Building Science Thermographer ITC/FLIR Certified Level 1 Thermographer |
| Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Check to see if it has a central fan unit down in the furnace room. Quite common in our area. Usually its piped in with solid tin ducting though? It typically vents out the side of the home down around the sill plate.
Darrell Hadler CMI Five Star Home Inspections Medicine Hat, AB. Canada NACHI# 04111082 Cell phone# (403)502-3593 Inspected once . . . inspected right! (website) http://inspectorpages.com/dhadler
Of course, the bath fans must go to the exterior. (and not just out into the eaves with perforated soffit but fully to the exterior through a vent hood.) |
Should be to the exterior.
Greensboro Home Inspection Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas. greensboro-home-inspection.html Raleigh Home Inspection Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas. Raleigh-home-inspection.html BassRumors.com Providing a blog, news, and forum dedicated to bass fishing. |
I think you are missing my point. I realize the foam was there to hold the hose in place and to provide a barrier. I realize they need to be exhausted to the exterior. Can anyone explain the building principal of running the hoses into the interior cavity of the home with NO means of exit and how could this EVER be an acceptable practice. That is my point.
Then Darrell's post #2 probably hit it right on....or were they planning on some central exhaust fan that never got installed? Last edited by Brian A. MacNeish; 2/3/10 at 2:24 AM.. |
The duct is undoubtedly going to the soffit.
I would also be incline to believe that this was a "homeowner" installation, rather than part of the original build. I would comment in the report that "the vent terminations were not visible and should be verified as venting to the exterior of the residence, or proper venting should be established by a qualified contractor." IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
My guess is with Joe. Just turn on the fan and listen for it outside.
Common around here. Stupid install. BTW: The bathroom exhaust pipe should be insulated.
Hope this helps; Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
This is what I typically see that happens when you vent an exhaust fan out an soffit vent. The one pictured may have even missed the soffit opening.
There are a few problems that I see with installing out a soffit. 1) reduced insulation 2) Stained sheathing It make more sense to vent towards a exhaust roof vent and not an intake roof vent like a soffit. I do have an illustration that states it can be vented out a soffit. See attached Last edited by dmacy; 2/9/10 at 5:10 PM.. |
I disagree for this reason: anywhere you penetrate your roof, you are more likely to have a leak. Punching holes in my roof would not be an option. My personal preference would be to vent to a soffit using an approved soffit vent (there would be no stained sheathing in that case). The insulation loss is negligible.
Time for another Global Warming summit!
I disagree with your disagreement. |
Your illustration showed a dedicated roof bathroom vent. I misunderstood your position. Sorry.
