Old 2/25/10, 6:59 PM
mivie's Avatar
mivie mivie is offline
Please Note: mivie is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default I haven't seen this before.
Is this O.k or not. What you are looking at is the box area at the return vent inside the home.
havent-seen-before-510-alston-hill-ct-041.jpg havent-seen-before-510-alston-hill-ct-042.jpg
Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/25/10, 7:07 PM
Bob Elliott's Avatar
Default Re: I haven't seen this before.
Where is the filter?
Old 2/25/10, 7:10 PM
Attachment 35225 Attachment 35226
Consider what type of air is being pulled through that cavity and also the that the box will draw from seams in the drywall along with cold basement air maybe.
Seems like there are always some issues when I see that setup.
Old 2/25/10, 7:20 PM
mivie's Avatar
I took out the filter for the photo. Yes it was nasty. This is located in the hall way.
Old 2/25/10, 7:35 PM
OK
Last question
Is it possible this location can allow air into the return from the furnace area.?
Think CO.
I had the boxes under the furnace and recommended ducting be added immediately.
Old 2/25/10, 7:37 PM
mivie's Avatar
No. It is for the Heat Pump air handler.
Old 2/25/10, 7:38 PM
Never see those here.
Next
Old 2/25/10, 7:41 PM
mivie's Avatar
Thanks Bob
Old 2/25/10, 7:46 PM
No problem, but seems like a flex duct could be thrown in for healthy air reasons.
Those filters only do so much.
Old 2/25/10, 7:49 PM
mivie's Avatar
I agree.
Old 2/25/10, 7:51 PM
Contrary to popular belief, the manufacturers state that the furnace filters are for the equipment not indoor air quality.
Larry Kage, CMI
231 929 3525
Old 2/25/10, 7:55 PM
Jeffrey R. Jonas's Avatar
I agree. The placement of the filter confirms that.
Old 2/25/10, 10:44 PM
Matthew K. Klein's Avatar
Matthew K. Klein Matthew K. Klein is offline
The truth is that the panel filters were primarily for equipment protection because they were mostly effective on the lint fibers floating around in the air and they make up about a third of the weight of the stuff floating around in residential air. In fact, the ASHRAE test dust used to test them for arrestance was about a third cotton linters. The panel filters kept the lint from reaching the cooling coil and fan blades, clogging them up. Back then, homes were pretty leaky and well ventilated.
Then, homes got tighter and this thing called indoor air quality came along. Filters then became important for removing the other stuff from the air that affected people. BTW, note the debris on the frame where air has been by-passing the filter for quite awhile. It illustrates a problem that most people overlook in that our ratings are for the filter media and NOT the filter system. Air bypass makes the system less efficient at trapping stuff than the filter itself.
Matthew Klein, P.E., M.B.A.
Criterium Engineers
PO Box 181503
Cincinnati, OH 45018-1503
Phone: 513-474-9600
FAX: 888-747-0427
E-mail: Criterium-Cincinnati@fuse.net
Website: www.Criterium-Cincinnati.com
Old 2/25/10, 11:26 PM
Chuck Forman, CPI's Avatar
Chuck Forman, CPI Chuck Forman, CPI is offline
I have seen this many times when I lived in Texas. Not the best IMHO, but it gets the job done, even though poorly. I have actually cleaned a few of them out for people just to make myself feel better.
Chuck Forman CPI
Forman Inspection Services
Denver, Colorado
720-641-9518 Office
720-988-3387 Direct
866-908-6872 Fax
http://www.formaninspectionservices.com
http://www.formaninspections.com
http://denvercoloradohomeinspections.com
http://coloradocommercialinspections.com
Email: chuck@formaninspections.com
Serving all of the Denver Metro Area!
If you shoot straight and tell it like it is, you will never have to worry over what you lied about yesterday....
John Wayne
Old 2/25/10, 11:30 PM
Is that why they make HEPA filters?
