Old 11/22/06, 6:38 PM
Jeffrey S. Campbell's Avatar
Jeffrey S. Campbell Jeffrey S. Campbell is offline
Send a message via AIM to jcampbell Send a message via MSN to jcampbell Send a message via Yahoo to jcampbell
Question Hearth size???
An inspection from a couple months ago... I am hearing throught the grapevine as clients have not called me yet... but the wood stove shown was removed by sellers, and the new owners (clients) are having a wood stove of similar size/style installed and the installer is stating the size of the hearth is too small or too low??? not sure... trying to get more info as we speak...
does anyone see an issue with it the way the install is in the photo? **** installers have issue with mantle... NOT hearth!
Old 11/22/06, 7:10 PM
gbeaumont's Avatar
Default Re: Hearth size???
Hi Jeff,
If the stove is not UL listed then the clearance are very large, here is a link on the subject to the Maine Fire Marchalls guide to clearances
http://www.mainefiremarshal.com/Docs...rningguide.pdf
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 11/22/06, 7:38 PM
I did not examine this stove as it was leaving with the sellers... but I am told they are putting in a "new one" which I would imagine would be UL listed... I just learned the issue is because it is being set inside the old fireplace... (the home is 200 years old)... the installers are havig issue witht he distance from the top of the wood stove to the Mantle above (you can just see a portion of the wood mantle) which is 18-22" above the old stove...
Old 11/22/06, 8:04 PM
Hi. Jeff;
The NFPA 211 12.5 states that non-combustible material at front and sides of front loading wood burning apparatus should be a minimum of 18".
Your picture seems to indicate that you have 20" and more on the sides, and you also meet the 36" min. to non-combustible from the unit.
I see no issue here.
Good luck.
Marcel
</IMG></IMG>
Old 11/22/06, 8:39 PM
phinsperger's Avatar
Hi Jeffery,
I do wood stove inspections up here and although our laws might be different I may also have an issue with the mantel clearance whether its projecting to not. I'd have to see it a bit better to be sure.
However the liability to make sure its up to snuff will fall on whoever installs the new stove so you off the hook in that sense.
Old 11/25/06, 1:14 PM
malban malban is offline
I don't know about your location, but many places require a building inspection to install a wood stove. I would advise your client to start by checking the at the local department of building and safety to see if local standards are in place.
Even if there are no local requirements, the building officials will steer you to the building code and section in use in your area. The stove manufacturer will also have installation guidelines available at their website. Google the manufacturer.
Michael Alban (TREC #9212)
www.1stabilene.com
1st@taylortel.net
Old 11/25/06, 3:33 PM
Joe Funderburk, CMI's Avatar
Originally Posted by jcampbell
I just learned the issue is because it is being set inside the old fireplace... (the home is 200 years old)... the installers are havig issue witht he distance from the top of the wood stove to the Mantle above...
How is that your problem? Wood stove clearances are determined by the manufacturer.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 11/25/06, 10:14 PM
Joe's right. Fireplace hearths have code requirements but not stoves.
Old 11/25/06, 11:18 PM
So the old one is gone. They're putting a new one in somewhere the old one was not installed - that has nothing to do with you - have a nice life folks.
Old 11/26/06, 2:11 AM
Joseph Hagarty,  CMI's Avatar
The "Older" stove may have met the Manufacturer's recommendation at the time of the original installation.
A "New" Stove must meet the current Manufacturer's recommendationswith regard to the current installation.
The physical characteristics of the Stoves may be the same and/or similar.
The installation guideline may now be different....
Joseph P. Hagarty, CMI
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 11/26/06, 2:22 AM
the hearth was not in question... it turned out it was the wood mantle exposed above the fireplace that will house the wood stove... see photo...
Anytime a client has a question, I try to answer it or direct them in the proper direction. I never said it was my problem, only i was looking to give the folks some guidance... in fact it was not the client rather a mutual friends/family that contacted me... the installers were giving them a hard time and they wanted the proper guidance... thanks to Gerry I was able to provide them with some information to help them understand the requirements... poor practice to tell them it is not my problem...
thanks again for all the comments...
Old 11/26/06, 2:34 AM
http://www.csia.org/pressroom/press-...-explained.htm
All Fireplaces, Stoves, Chimneys and Flues require a Level 2 Inspection prior to closing (per NFPA Standard 211)
This has been the Standard for over 6 years.
Phone: 610-399-3675
Old 11/26/06, 11:37 AM
easy now... know your states... this is the quickest article I could find... but Maine is not quite there yet... but we are getting there...
In other states, a level 2 inspection is required anytime a property changes hands, but not in Maine. Maine adopted the NFPA standards in their entirety in January, except for the real estate transfer portion. Parlin said the Maine Association of Chimney Service Professionals will be going back to the Legislature to try again.
http://pressherald.mainetoday.com/ho...05chimney.html
Old 11/26/06, 11:43 AM
"Maine adopted the NFPA standards in their entirety in January, except for the real estate transfer portion"
Maine did not adopt the NFPA Standard.
They settled for and adopted a less than minimum standard of their own.
Phone: 610-399-3675
Old 11/26/06, 11:47 AM
Let me ask those of you doing level 2 chimney inspections hand in hand with your general home inspections, assuming you are properly qualified, are you getting extra $$ to do so?
we have professional chimney sweeps that will charge for doing this service but curious how the rest of the profession operates... should i get certified in light of pending requirements... as stated Maine does not require a level 2 at this time... but like everything, things change...
remote camera scanning equipment looks expensive... worth it????
A/C Breaker size dnice Electrical Inspections 31 9/21/07 3:45 PM
Picture size? waksell Miscellaneous Discussion for Inspectors 4 1/25/07 4:47 PM
Flue Size when size matters? msylvester Inspecting HVAC Systems 14 1/21/07 12:29 AM
No hearth on gas logs kblair1 Inspecting HVAC Systems 9 12/21/06 5:21 AM
Help Determining Reportable Service Size cbarrows Electrical Inspections 8 7/19/06 8:12 PM
