Inspected a home with no "permanent" heat source in one of the bathrooms - except for a ceiling mounted heat lamp. I would consider the heat lamp a temporary heat source. Thoughts?
774 Manor Road Staten Island, NY 10314 718-514-3393 |
| Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
If it's a built-in fixture, it's permanent. "Temporary" heat sources are generally "portable" type heaters with a cord & plug.
A building inspector here in Nevada told me that to be habitable the heat source has to maintain 70 degrees 3' off the floor.
Thing is with older "pot" lights and heat lamps......they were put in before higher levels of insulation were needed.....they are not approved to have insulation installed over them. Could be a fire hazard. Do you check this item?
Was the system up flow or down. Just wanted to mention on a downflow most bathrooms have a toe board under the Lav. Just in case you overlooked
There was no access to the attic area above. I probably would have reported on that if I could have seen it. 774 Manor Road Staten Island, NY 10314 718-514-3393 |
I did almost miss one of those toe board sources on one of my inspections. I look for them now. I always double check myself, by going back to each room once I've got the heat going to confirm the heat source. 774 Manor Road Staten Island, NY 10314 718-514-3393 |
| efficiency of 15 yr old peerless | afrost | Inspecting HVAC Systems | 11 | 11/19/07 9:51 AM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 8:17 PM |
| Radiant Heat Transfer | rmyers1 | Structural Inspections | 0 | 5/31/06 11:21 PM |
