Serial# 0008539877-P13-0022
Model# DEBD020G-BV Can you tell the capacity by these #'s Thanks "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
Almost always there is a three-digit number within the model number—in this case, 020—that tells you the capacity. One ton is equivalent to 012, so 018 would be a 1˝-ton unit, 036 a 3-ton unit, etc. NACHI 2005 U.S. Member of the Year
Russel
This is a heat pump. The outside unit is a 3ton. Is the inside unit just an air handler, correct. "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
Thanks Ray
You are a big help and we appreciate it. "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
| Heat pump in a 80+ year old masonry house | jskrypka | Inspecting HVAC Systems | 9 | 11/25/06 11:47 PM |
| Carrier heat pump fires? | lprinzi | Inspecting HVAC Systems | 3 | 10/12/06 8:31 PM |
| Question on my heat pump | dbush | Inspecting HVAC Systems | 7 | 3/12/06 1:15 AM |
| Armstrong heat pump -- good or bad? | skipswift | Inspecting HVAC Systems | 3 | 2/13/06 10:17 PM |
