Scenario:
Finished basement (walkout). Heat Pump air handler and electric heat strip located in an interior closet with 30" louvered door. Client says his brother was told needed exterior rated door with threshold and weather stripping. Never heard this before and can't find any code requirement. What say U? |
got any pics?
With the a/c or heat on, is the door hard to open? Is there a lot of dirt/dust build up around the door or in the closet? John J. Passailaigue Jr. NACHI05062580 Auburn Home Inspection Auburn, Alabama WAR EAGLE!
New house John.
I had no issues until client asked if solid door with threshold and weatherstripping was required. Can't find any code reference that deals with it other than clearance requirements. Thanks |
I don't think there is a problem. I have never seen an exterior rated door indicated for this aplication.
James R Lilly, CMIA www.lhiservices.com jamesrlilly@lhiservices.com Home and Mold Inspections Radon Testing Based in Parkersburg, WV Serving West Virginia and Ohio |
It doesn't even need to be in a closet, much less a sealed closet. . .
Sounds like the requrements fo natral gas in enclosed area.
Thanks everyone for your responses.
A "Non-issue" is where I was and still am. Thanks again. |
They can change out that door and make things quieter so long as there is a return air duct system.
If this is a free return design, that is the reason for the louvered door. There would not be any duct work at the bottom of the air handler. |
Calvin
No need for louvered door, because there is no combustion question, being an all electric system. Clearances still a question, but typically 1" clearance on an all electric (kw strip heater - internal mount is no problem) AHU. I'd want a solid door w/ weather/sound dampening gasketing for noise purposes. Wood would/should meet local code. |
| something else to chew on | john bubber | Structural Inspections | 706 | 4/25/12 7:13 AM |
| Radiant ceiling heat? | bmargiotti | Inspecting HVAC Systems | 16 | 1/24/12 10:46 AM |
| Heat pump in a 80+ year old masonry house | jskrypka | Inspecting HVAC Systems | 9 | 11/25/06 10:47 PM |
| Question on my heat pump | dbush | Inspecting HVAC Systems | 7 | 3/12/06 12:15 AM |
| Armstrong heat pump -- good or bad? | skipswift | Inspecting HVAC Systems | 3 | 2/13/06 9:17 PM |
