I know heat pumps have been discussed may times. If there is a good archive on the board let me know.
Would anyone have a checklist for inspecting a heat pump and the emergency heat? I have a 3100 sq. ft. home with a zoned system that has 3 heat pumps and the home is a electric. The home is located in Northeast Ohio and I will be testing the heat mode. I do understand about the reversing valve. Thank you for your time Dave |
David,
Being up in Ohio at this time of year you at least won't have to worry about the air conditioning part. Most heat pumps I have done have a 2 degree set on the thermostat so if you raise the temp that much over current temp, the back-up / strip heaters will turn on and usually show a light on the panel. Don't forget to defer the air conditioning portion. The secret of heat pumps is to move lots of air. I always recommend 60 day filter changes instead of 90. Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Here's a pretty good heat pump inspection description from ITA: http://www.home-inspect.com/itatips/11-04.asp
If you have 3 units on 3100 SF, I doubt you have a zoning system because it would not be needed.
Zoning is installed to use 1 unit to do two levels or areas or 2 units to do even more. A true zoned system has a control box somewhere and motorized dampers in some of the ducts. When inspecting a system with zoning be sure to disclaim the performance since it is based on programming, installation details and very dependent on outside temp, insulation quality etc. I tell clients to learn the system or find a qualified hvac guy because they can be tweaked over time to provide good results. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Bruce,
What is the context of your disclaimer, If I may ask. I see alot of zoned systems and have wrote some up for producing marginal temp drops in certain areas of the home... Just wondering how you'd word it. - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
![]() ![]() ![]() ![]() I hope this helps. |
Mike this is all I add since the SOP's already disclaim a lot of hvac performance.
Zoning info for reports: A zoning system is present that allows a single smaller hvac unit to serve a larger area by controlling duct valves with electronics that have two thermostats present in the house. It is recommended to obtain the owners manual and consider learning how to or obtain assistance in making adjustments to obtain the optimum performance based on the actual use of the home if the performance is not satisfactory. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Thanks Bruce,
I use something similar though I don't think it's as detailed. On the road so I'll have to look when I get home... - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
Great info.
Gary Porter GLP's Home and Mold Inspections 321-239-0621 Certified Commercial Mold Inspector Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford Orange County, Seminole County, Volusia County, Osceola County www.homeandmoldinspections.com |
We have a lot of "zoned" systems here in San Diego, up to six that I have found. I have never found one control for all six systems and, quite frankly, I would probably find that inconvenient. I don't want to walk through 3,000 SF of space and stairs to get to the control for my master bedroom in the middle of the night.
The zoning systems here simply have a thermostat in the master bedroom, one in the living room/family room/game room, one for the kitchen/dining room, one for the guest suite, one for the bedrooms, etc. Since there is nothing unusual about standard thermostats, people in various parts of the house can operate their zone as they see fit. |
Russel,
The control box might handle several thermostat demands but you do not have to "walk to it to make temperature adjustments". It is not for everyday use and is usually in the attic. The control box can be programmed to decide which thermostat gets priority and at what differential. A house with six thermostats probably has more than one control box. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Never seen such a device connected to all the furnaces. Particularly never seen something like that in the attic. Zoned furnaces here act individually from each other, which can be inconvenient, but still is better than having all six going at the same time from one thermostat.
I lived in while renovating a dual-zoned, 4000 SF house a few years ago. The giant living room was in the middle seperating the bedrooms from the rest of the house. Unfortunately, both furnaces serviced the living room, and two sides of the living room were floor to ceiling windows to take in the view, and the living room faced south. So it got extremely hot in there during the summertime. So if one wanted to sit in that room, and the view definitely encouraged one to sit in there, one had to turn on both thermostats to cool the room down. Unfortunately, the rest of the house became an igloo by the time one was finished sitting in there. I installed reflective tinting on all the windows which helped, so when I sold the house after renovating (and I sold during the summertime), the living room was quite comfortable. Window tinting. Best thing that ever happened to windows until multi-pane windows came along. Unfortunately, they don't make 6'x35' multi-pane picture windows, and breaking up the picture windows into lots of tiny windows would have destroyed the impact of the view. |
Russell,
I never said the control box was connected to more than one system. It is connected to more than one thermostat. Other info just to help others: A home with two or three hvac units usually does not have zoning. The thing that indicates zoning are when there are more thermostats than hvac units. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
Honeywell Zone Systems and Controllers
http://customer.honeywell.com/Honeywell/ui/pages/catalog/ApplicationCategory.aspx?Catalog=Homes&Category=HV AC+Zoning_130&ChannelID=%7b2EB2F178-20ED-44E0-97FB-CCFB4218DD64%7d Smarthome http://www.smarthome.com/3038.html Commercial Applications... http://www.autozonecontrols.com/ Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member Last edited by jhagarty; 1/14/06 at 9:43 AM.. |
As to emergency heat, my experience has been to switch the thermostat to emergency and let it run. See if the duct heats up. You won't necessariyl know the electrical portion of the emergency heat is functioning or burnt out elements unless you check it with an electrical meter. Thats beyond the scope. So you could feasibly have one or two elements burnt out and not know it. I always recommend service prior to closing of title on Heat Pumps which do not appear to be functioning properly or which are old.
Raymond Wand Alton, ON |
| Moisture on pad at heat pump condenser | lfoster | Inspecting HVAC Systems | 3 | 5/2/07 5:38 PM |
| age of a GE heat pump | rschlater | Inspecting HVAC Systems | 3 | 2/11/07 7:36 AM |
| Frozen Heat Pump | hmcbride | Inspecting HVAC Systems | 10 | 2/2/07 9:18 PM |
| Heat Pump | psmothers | Inspecting HVAC Systems | 66 | 7/20/06 12:15 PM |
| Anyone created a Home Inspectors Electrical Check List | jsieg | Electrical Inspections | 29 | 2/7/06 1:55 PM |
