Old 3/14/11, 5:43 PM
John Evans John Evans is offline
Default Heat Pump Garage Attic
A first for me, heat pump air handler located garage attic with supply and return ducts located house living space and the GARAGE. I know the ducts to the garage space must be removed. Question, can the air handler remain in the attic to supply conditioned air to the living space? With no combustion air needed for a heat pump, the location may be OK, responses would be appreciated.
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Need a home inspection in South Carolina? Check out InterNACHI's listing of South Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/14/11, 5:50 PM
Stephen W. Stanczyk's Avatar
Default Re: Heat Pump Garage Attic
I wouldn't have a problem with the air handler located in the attic. Other than being a pain to change the filters (unless located elsewhere) and making sure there is an appropriate drain pan and condensate line installed, I don't see an issue.
It must be an attached garage so where is the access to the unit? Did the firewall get breached with drop down stairs? or is the garage attic separated from the rest of the home's attic?
Homes that have furnaces / air handlers in the garage have ducting in this area all the time. Do you mean ducting or registers / return air vents? Ducting could be present as long as it is sealed properly.
Stephen Stanczyk
Old 3/14/11, 6:14 PM
Supply and return ducts terminated both in the garage and within living space.
Old 3/14/11, 6:38 PM
Tom Leahy Tom Leahy is offline
The return is a "no no" in the garage. Along with the fire breach if thats the residence side. But definitely a write up. I've thought about adding a register in my shop area of the garage and checked with the insurance co. just in case of a fire and said I would still be covered. Went ahead and put a window unit in instead.
Fort Worth Home Inspector
Dallas Home Inspector
heat pump - freezing temps last winter lfoster Inspecting HVAC Systems 8 6/22/10 10:05 AM
Garage door inspection procedure bgromicko General Inspection Discussion 5 8/7/09 12:47 PM
Radiant Ceiling Heat hhull Interior Inspections 9 7/26/07 8:19 AM
Carrier heat pump fires? lprinzi Inspecting HVAC Systems 3 10/12/06 7:31 PM
Question on my heat pump dbush Inspecting HVAC Systems 7 3/12/06 12:15 AM
