Old 10/28/09, 7:26 PM
Bob Elliott's Avatar
Default Heat Pump? What the heck is that?
Here in Chicago that is a foreign word and all I know is they do not get very hot and work kinda like an A/C unit in reverse.
I did a multi unit hi-rise 100 years old with this systen in place.
Here is a picture of what was on the roof.
Here is what is inside the 100 plus Living Units.
I know the boilers on the roof are Ajax 25 years old and I know the smaller units with the blowers are Snyder General with serial number J2671502 and Model number V024aegl on this one.
20 amps double breaker to it.
Top sheet metal is to ceiling vents (ducts)
It has freon so where does the hot exhaust go to?
I am used to a main hot water boiler and chiller unit (central) running H20 through an exchanger with blower in individual living units but this has me stumped.
Can someone give me a crash course here on the basics?
Find an InterNACHI certified Illinois Home Inspector (and anywhere else in North America)
Old 10/28/09, 7:47 PM
Bruce A. King's Avatar
Default Re: Heat Pump? What the heck is that?
I don't see a heat pump, you have a hydronic system, google it, I don't have time right now to post more.
edit: water source "heat pump" but not typical air source heat pump as we have around here.
www.BAKingHomeInspections.com
704 301-3207
Old 10/28/09, 8:02 PM
I am told this is a heat pump system and temp does not go above 85 degrees.
The Head Engineer explained that's what it is.
Anyone?
The plate shows it holds R 22 .
Old 10/28/09, 8:49 PM
William Warner's Avatar
William Warner William Warner is offline
The first pics are of course boilers
The second pic appears to be an air handler for the hydronic heat (think heater core like an automobile - common in some condo construction even today - some manufactures utilize the hot water from a water heater). Perhaps it had an evaporator installed (hence the R22 tag)... but there would need to be a compressor somewhere and refrigerant lines running to the handler. I don't see any refrigerant lines in the pictures. There may be a heat pump installed somewhere at the property, but your pictures do not depict one.
Visit the InterNACHI Awards web portal here
Blessed are the blissfully ignorant... for they shall be easily led...
Old 10/28/09, 9:14 PM
Yeah I do not see a compressor or lines so that is whats killing me.
I do not usually miss much.The Building Engineer comments and being unfamiliar threw my game off.
I know those boilers are heating the water so I just do not see where the heat pump part of it comes in.
Both seller and engineer stated the same thing separately.
There was a schematic that used the term also.
Interesting is that I did not notice a site glass on the boilers.
Old 10/28/09, 9:24 PM
Sean Fogarty's Avatar
I look at hydronic systems in condos all the time. The a/c is split, so the compressor should be outside somewhere. If you open the panel on the inside unit, you should see 2 coils. One should be triangular for the a/c part, and the other should be flat and look like a car radiator. The two water lines should be going to the flat coil. When I test the condo units, I just turn on the heat and put my hand on the line. When the water pump starts moving the water, the line will heat up in my hand. That is how I know they are working. These units are great for small areas, but anything over 1200 sf, and the water heater has to be turned up too much to handle it.
Sean Fogarty
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
www.homeinspectionknoxville.com
Old 10/28/09, 9:27 PM
Gerry Pallotta's Avatar
Gerry Pallotta Gerry Pallotta is offline
Send a message via Yahoo to gpallotta
Possibly engineer pulling your leg?
Old 10/28/09, 9:33 PM
Bob, one last thing. If it truly is a heat pump. You will have both a heat and emergency heat selections on the thermostat. The em heat is for just turning on the heating strips. If there is no em heat selection then it will not be a heat pump, just a conventional heater.
Sean Fogarty
865-256-5397
Old 10/28/09, 9:42 PM
David A. Andersen's Avatar
Not a heat pump.
You have a boiler and the two lines are for hot/chilled water supply and return.
R-22 Refrigerant (Not FREON, you need to quit using that word) makes chilled water for a/c cooling.
BPI# 5015804
Old 10/28/09, 9:51 PM
Wayne B. Wilson's Avatar
Yep it looks like a chiller bob.
Old 10/28/09, 10:04 PM
I did not see a big chiller unit on the roof.
But thanks since everyone is in agreement.
Call it a brain freeze .
First time since my very first inspection I got stumped like this.
I will post here if something new is found out.
Guess I will start reading about Heat pumps, just in case so this never occurs again as it made me feel like a rookie all over again.
Old 10/28/09, 10:06 PM
Bruce M. Graham, III's Avatar
Bruce M. Graham, III Bruce M. Graham, III is offline
that is a water source heatpump, with a circulating water loop, there will also be a cooling tower on the roof. the boilers heat the loop water to maintain say 85deg water in the winter time. sorry for tha caps and limited info I can't get the cat out of my lap.
most of what I worked on and installed for 14 years, was this type of system.
pm me if you would like more info
Bungalows to Mansions
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 10/28/09, 10:11 PM
Originally Posted by bgraham View Post
that is a water source heatpump, will a circulating water loop, there will also be a cooling tower on the roof. the boilers heat the loop water to maintain say 85deg water in the winter time. sorry for tha caps and limited info I can't get the cat out of my lap.
most of what I worked on and installed for 14 years, was this type of sytem.
Ah Hardware
So it is a heat pump type system.
I do not feel dumb anymore,just ignorant.
Bruce I just emailed the report but if you can tell me more about this system and how these boilers interact with the apt Unit it would be great.
email me at bob@homeinspectorpro.com.
I really hate not knowing something.
Old 10/28/09, 10:37 PM
Bruce, where do you see a Heat Pump device in the pics?
I missed it.
Bob posted nothing that indicates a heat pump.
Please post what you have here as well.
Your terms are a bit confusing.
"Water source" (vs. air source) is where the heating and cooling medium is derived.
Water coil (vs. DX coil) is the heat transfer device.
"Forced air" is the distribution type.
I could see that boilers are needed in Chicago to supplement a heat pump because of the region and heat loads.
Not if it is a water source heat pump in a climate zone where supplemental heat is not required. Don't confuse anyone.
BPI# 5015804
Old 10/28/09, 10:55 PM
Perhaps he found info from the serial number.
Radiant ceiling heat? bmargiotti Inspecting HVAC Systems 16 1/24/12 11:46 AM
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing & Legal Issues for Inspectors 50 4/20/08 2:26 AM
Heat pump in a 80+ year old masonry house jskrypka Inspecting HVAC Systems 9 11/25/06 11:47 PM
Question on my heat pump dbush Inspecting HVAC Systems 7 3/12/06 1:15 AM
Heat Pump Check list for inspecting dmacy Inspecting HVAC Systems 21 2/1/06 1:56 PM
