| HVAC Topics include heating, venting, and air conditioning. |
How does everyone inspect heat pumps? I know this has been asked before, but I can't seem to find the thread I viewed last month. Thanks
Chuck Yezza, President 1st Choice Property Inspectors Inc. NACHI #05012083 Concord, Ohio 440-6678458 cyezza@roadrunner.com www.1stcpi.com |
Without writing an essay...
Just make sure you understand when and how the electric strips come on and how they can mislead you into thinking the heat pump is working properly when it may not be. There are also new features in units that may change when the strips operate. |
Much more involved with modern units than just the coil....
Heat mode uses a lot of circuitry on the defrost board that cooling does not use. |
So in the Winter time, I do you inspect Heat Pump in both Modes? Just Defer Cooloing Mode right? Chuck Yezza, President 1st Choice Property Inspectors Inc. NACHI #05012083 Concord, Ohio 440-6678458 cyezza@roadrunner.com www.1stcpi.com |
So here is my answer; just depends on the outside ambient. I always start the unit in the winter time in the heat mode this ensures that there is no liquid lying in the crank case of the compressor as heat pumps also have crank case heaters. Compressors are designed to pump vapor not liquid. I do not run in the cooling mode if the outside ambient is down in the twenty's or below just a personal choice. Could I; probally so with the unit first being operated in the heat mode. Would you get good readings in the cooling mode; no they would be squirrelly. About the only thing you can accomplish operating in the cooling mode is the fact that you can say yes it does switch from heat to cool. Are you going to blow the valves in the compressor switching to cool my HVAC answer is no. Sorry I left off an item of concern relating to switching from the heat mode on a heat pump in the winter months to the cooling mode. The unit its self reverses automattically to the cooling mode when ever it goes into defrost cycle with the exception it drops the condenser fan out of the curcuit to bring the head pressure up to help defrost the ice on the condenser Last edited by cbottger; 1/10/07 at 6:35 PM.. |
To add...
If you are going to switch a reversing valve in the off season, it should be done at the condensing to you can evaluate it in a very short time. You can't switch it and walk out doors, or wait for the suction line to get warm way up in the attic. If you don't know how to switch the reversing valve from outdoors (way outside the scope of HI Standards) I would not recommend it be done. |
The heat pump changes automattically to the cooling mode when the unit detects a need for defrost it just reverses the flow again and places heat back on the condenser again as it is in the cooling cycle but it drops the condenser fan out of the circuit or simply reduces the RPM depending on the MFG. David I think was referring to operating a heat pump in the heat mode during the summer months. |
Thanks Charlie.
I had to run. Thanks for the good reply. Yes, I was discussing a "quick test" in the heat mode during summer conditions. We don't want high head pressures, so it must done quickly. Winter time testing is no problem (as posted). The heat pump runs in the a/c mode about every 45 min anyway and will not be damaged. |
I am lucky if I see a dozen air to air heat pumps in a year here and probally no more than 2 ground source in a year. I do nothing spectacular over a regular A/C unit. But I do want to see the reversing valve change positions as I don't want to buy one they can be expensive to change out. There is nothing an HI can determine about the defrost cycle unless you just happen to be lucky and catch the unit in defrost or unless the unit has a large amount of ice build up on the condenser fins indicating the defrost is not performing as intended. Defrost cycles are generated by an embedded temp sensor within the condenser coil and when the factory non-adjustable temp is obtained it goes into defrost or I suppose this cycle could be generated on these newer units according to run time and a solid state board. In any event the HI should just disclaim the defrost cycle unless you can see excessive ice. I operate the heat pump generally speaking in both modes heat and cool. Normal on the thermostat. I also check the emergency heat mode and I use my amp meter if the unit has electric heat strips. When I switch to the emergency mode I walk back out to the outside unit to ensure that it is not operating. The two most important items that I am concerned with is the reversing valve and are the heat strips being activated when the unit is in the normal heat mode as I have found this to be the way the installing contrator left the unit wired on numerous units. I use my amp meter again to determine if these strips are activated or not. |
| Heat pump in a 80+ year old masonry house | jskrypka | HVAC | 9 | 11/25/06 11:47 PM |
| Carrier heat pump fires? | lprinzi | HVAC | 3 | 10/12/06 8:31 PM |
| Question on my heat pump | dbush | HVAC | 7 | 3/12/06 1:15 AM |
| Armstrong heat pump -- good or bad? | skipswift | HVAC | 3 | 2/13/06 10:17 PM |
| Heat Pump Check list for inspecting | dmacy | HVAC | 21 | 2/1/06 1:56 PM |
