Old 12/18/06, 6:55 PM
apolillo's Avatar
apolillo apolillo is offline
Please Note: apolillo is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Heat Pump or not
Fellow Inspectors,
Last week I had townhome with all electric hvac. I wrote up that the condenser unit was a heat pump (reverse valve visible) and the t-stat did not have the option for emergency heat. The unit did not operate in heating mode. Today I was back to view a number of items including a new roof. The seller showed me the sales contract for the unit. It stated that the system had be sold as AC only and Electric furnace.
I informed my client that while the unit does operate, she could probably save a chunk of change, by having system checked by her choice of HVAC contractor, to see if she could take advantage of the heat pump option.
Have any of you seen a similar installation ???
Anatol
Old 12/18/06, 7:39 PM
Brian E. Kelly's Avatar
Default Re: Heat Pump or not
If it gets cold there in Maryland Anatol running the heat pump is not the answer. Better off running the electric furnace IMO.
Old 12/18/06, 8:24 PM
Roy D. Cooke, Sr's Avatar
I understand below about 32 degrees F the efficency is poor and many switch over to resistant heating ,above 32 is the best gain over resistant heating
some more info here http://www.flex.net/~lonestar/hpumps.htm
Cookie
Old 12/18/06, 8:59 PM
apolillo's Avatar
I see lots of heat pump systems here. My concern was for my client energy costs. Seems a shame to have a heat pump and not take advantage of it. Winter temps average about 35-40 nightly, so for me it makes sense to have the option.
Anatol
Old 12/18/06, 9:28 PM
Robert J. OConnor's Avatar
Good recommendation IMO ... in moderate temperatures heat pumps can be a good option and very efficient. Even in colder regions a HP with supplementary electric heat is better than just electric heat alone (although usually not as good an option compared to a gas or oil fired system) ...
Still scratching my head as to why they didn't set it up as a heat pump (assuming the outdoor unit is indeed a heap pump unit), with the electric as supplementary/auxiliary heat only as needed. Maybe the contractor didn't know how to wire that system ...
P.S. Best way to ID an exterior heat pump unit is to look inside the outdoor unit for a reversing valve (see typ pic attached).
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 12/18/06, 10:03 PM
Doug Edwards,  CMI's Avatar
Not much of a contractor then. The thermostat comes with installation and wiring instructions. Your call to have an HVAC contractor (only not the same numbskull that installed it the first time) come and set up the Heat Pump correctly is the right call. During milder weather the Heat pump will operate like ....well, a heat pump. When it does get very cold it will operate...well, like a heat pump in Emergency Mode, like it is suppose to. Either way it should be set up properly for all the right reasons. Many of the old assumptions and stories about Heap pumps are no longer the case. We have some periods of extremely cold weather here and there are a bazillion heat pumps as the primary heat source. The Heat pump of today is not the heat pump of 10-15 years ago. If it is an old antiquated POC it is probably overdue for replacement and if new and properly sized for the home it will do just fine, once it is properly wired and the thermostat is actually working as intended.
Old 12/19/06, 12:44 AM
Michael R. Boyett's Avatar
...and the t-stat did not have the option for emergency heat.
Remember some new t'stats don't have the separate on/off switch for emergency heat like the older t'stats. It is programmable on some of the LCD types. I saw one just a couple of weeks ago and had to research it to confirm that was the case. That was, up to then, one of the ways I quickly identified a heat pump.
Thermostat looked like this: http://nachi.org/forum/attachment.ph...2&d=1164863937
Old 12/19/06, 2:56 PM
David A. Andersen's Avatar
That t-state does have an EMER setting if used as a five wire aux heat setup.
The only time that you will have a t-state without an em/aux heat setting is if the AHU does not have aux heat strips. These may be found in warm areas like AZ and TX.
Old 12/19/06, 3:50 PM
I think what Mike is saying is that for heat pumps he is used to seeing a manual T-Stat with a switch on the outside that can be moved to the "EM Heat" setting ... like in the attached pic.
Also always take a look inside the outdoor unit when doing the exterior part of the inspection, and look for a reversing valve inside the unit. It should be pretty obvious when you see one (see my post above).
JMO
Robert O'Connor, PE
Heat pump in a 80+ year old masonry house jskrypka Inspecting HVAC Systems 9 11/25/06 11:47 PM
Carrier heat pump fires? lprinzi Inspecting HVAC Systems 3 10/12/06 8:31 PM
Question on my heat pump dbush Inspecting HVAC Systems 7 3/12/06 1:15 AM
Armstrong heat pump -- good or bad? skipswift Inspecting HVAC Systems 3 2/13/06 10:17 PM
Heat Pump Check list for inspecting dmacy Inspecting HVAC Systems 21 2/1/06 1:56 PM
