Question for someone with more knowledge then me.
1993 home has a Trane heat pump at exterior. Furnace is gas Trane brand also 1993. Thermostat has no emergency heat mode. My question is about the heat pump mode and configuration. How does the exterior electrical, heat pump box near interior components function? Had power when I opened small box for heat pump. It appears to be a gas furnace with an electric AC unit but I could not tell if the Heat pump mode operated or was functional. How does the system know how to switch from gas, electric heat pump mode if no emergency heat function at the thermostat. I could use some explaining, education on this one. Thanks, see pics. Performing Home Inspections in Cleveland, Strongsville, Brecksville, Broadview Heights, North Royalton, Parma and surrounding areas. |
| Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Your furnace was most likely installed with a standard A/C and the owner got sold a heat pump at a later date. Did the date of MFG match or were they different. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
I know they are duel fuel.
Both the exterior unit and Inside system are the age of the house 1993. I have a dual fuel system and my thermostat has an emergency heat. This house thermostat did not have an emergency heat. My set point is 30 degrees. How does this heat pump system know how to differentiate from gas to electric? Like I stated not seen a set up like this!! Thanks!! Performing Home Inspections in Cleveland, Strongsville, Brecksville, Broadview Heights, North Royalton, Parma and surrounding areas. |
The emergency on the stat is to be used if the outside unit fails the normal operation can and does bring the gas unit on if needed and during the defrost defrost cycle. Did you try to run the stat up 3 or 4 degrees above its setting and see if the gas kicks in. You may have a improperly installed stat but on the other hand depending on its wiring if the outside unit failed the gas furnace auto picks up the load. Sorry not much help from afar just to many variables Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
I understand, you need to be there!! Thanks for trying to help me!! Performing Home Inspections in Cleveland, Strongsville, Brecksville, Broadview Heights, North Royalton, Parma and surrounding areas. |
It is possible someone just using the heat pump as standard A/C one could tell this by the amount of control wires traveling to the exterior unit from the furnace. It there are only two low voltage wires it is for cooling only if more than two wires it is used as a heat pump Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
There is like an entire electrical service meter on the outside (without the glass dome) in addition to the typical exterior disconnect. It was a different set up then I am used to. Pic of exterior components on original post. Performing Home Inspections in Cleveland, Strongsville, Brecksville, Broadview Heights, North Royalton, Parma and surrounding areas. |
Why do you need an emergency heat setting on the thermostat?
If you want one. Change the thermostat. It does not effect the operation of the unit. "working together to get-IR-done" Bracebridge, Ontario: Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
It does on mine!! Performing Home Inspections in Cleveland, Strongsville, Brecksville, Broadview Heights, North Royalton, Parma and surrounding areas. |
| New HWT design | kwood | Green Building Inspections | 1 | 11/8/12 3:17 AM |
| Heat pump in a 80+ year old masonry house | jskrypka | Inspecting HVAC Systems | 9 | 11/25/06 10:47 PM |
