Home has a 2 ton Carrier air source heat pump. 17 years old
Temperature at time of the inspection was 15 degrees. It was operating in the heat mode and heating properly. I do not get how it was extracting heat from the outside air at 15 degrees. Mine is set at 30 degrees and it is a 2008 unit. I do not understand how the exterior unit can take 15 degree air and operate properly. I also tried in emergency heat mode and it operated. |
| Find an InterNACHI certified Ohio Home Inspector (and anywhere else in North America) |
What do you mean by "mine is set to 30 degrees" ?
Is that when it switches over to an aux heat source? Heat pump operation depends on the type of refrigerant, the newer R410 is much better since it is used in units that have other advanced designs. At 15 deg F, some heat can be absorbed from the exterior but most likely it was running in regular and aux heat strip mode at the same time if you had good warm air. If you had the t-stat up over 2 degrees it would have been running the electric strips also unless programmed out via a special t-stat that also uses an exterior temp sensor. Some units can even sense that the house is not gaining any heat and will add in the aux strips even at a one degree t-stat command. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
The thermostat at this home indicated it was running in normal heat mode. The heat pump was running when I arrived and I tried turning up 10 degrees to see if the aux heat would automatically turn on. It did not. |
| Radiant ceiling heat? | bmargiotti | Inspecting HVAC Systems | 16 | 1/24/12 11:46 AM |
| Heat pump in a 80+ year old masonry house | jskrypka | Inspecting HVAC Systems | 9 | 11/25/06 11:47 PM |
| Question on my heat pump | dbush | Inspecting HVAC Systems | 7 | 3/12/06 1:15 AM |
| Armstrong heat pump -- good or bad? | skipswift | Inspecting HVAC Systems | 3 | 2/13/06 10:17 PM |
