How would you confirm that the back up heat strips are working in a heat pump system that does not have an emergency heat switch? Using normal controls.
Thankyou
Normal controls will not give you the answer -- There is no yes or no light that will turn on
This will go passed the SOP rlb |
The old system that we had in our home did not have an emergency heat switch and I was wondering how to test the heat strips. Now I understand.
You are Welcome |
No EM Heat Switch; wrong T-Stat installed.
To Test (without tools); Look at the electric meter before going into the house. Go turn the t-stat all the way up. Go back out and watch the electric meter. |
I agree, wrong T-stat present.
Many meters here are digital, I like to see the disc spin on the older ones. |
Lived here 17 years, same thermostat as every other house I have been in, in this subdivision of about 250 homes. Maybe they figured we wouldn't need Emergency Heat way down here in Florida. I don't know.
That makes sense. I was under the impression that all heat pump systems had some kind of Emergency Heat.
Most units also automatically turn on the heat strips during the defrost mode to cancel out the cold air during the 1-2 minute A/C cycle.
The cost for heat strips is not that much and most contractors include them around here. IF the t-stat has the feature and they are not working, I write it up as a broken or missing item. |
I overlooked your location! :-0 If you live in the right zone where heat strips are not needed, a standard t-stat is much cheaper and acceptable. In this case you can't determine if the strips are working, right? |
| Ducane Heat pump and air handler dates?? | tallen | Inspecting HVAC Systems | 19 | 12/30/09 4:11 AM |
| Frozen Heat Pump | hmcbride | Inspecting HVAC Systems | 10 | 2/2/07 10:18 PM |
| Heat Pump Identification | cyezza | Inspecting HVAC Systems | 11 | 12/1/06 9:40 AM |
| Heat pump in a 80+ year old masonry house | jskrypka | Inspecting HVAC Systems | 9 | 11/25/06 11:47 PM |
| Armstrong heat pump -- good or bad? | skipswift | Inspecting HVAC Systems | 3 | 2/13/06 10:17 PM |
