1989 Trane heat pump air handler wall mounted in a small utility closet 1st floor of a slab on grade townhome. Unit is mounted about 4' off the floor with no return plenum. The bottom of the cabinet is open, closet acting as the plenum? 2nd floor wall cavity return with no draw. HVAC guru's, what do you think?
| Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Can't do two floors with one unit on a good day (even when you have a well designed return duct)!
How do you get hot air from 2nd floor down? Can't Fire code violation? "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Fire code violation due to the open wall? How is the return air flow supposed to work on the first floor when the "return" is located behind small louvered doors? Ridiculous design, second floor air flow is hopeless. I don't think Trane would endorse this installation.
Disregarding the lack of a functional return on the 2nd level, it sounds a lot like how a mobile home is designed. System in a closet, serving as the plenum. The filters directly over the A coil never work well.
rsummers is a non-member guest and is in no way affiliated with InterNACHI or its members.
It was probably OK with building dept to use building cavity's when system was original installed as long as the openings were large enough to allow a sufficient flow of air back in unit & there are no issues with Fire code violations or issues like drawing in air from unconditioned spaces. In the past this was not uncommon you could never get away with it now. They sure spent a lot of time on the filter rack must have been a real money maker for the contractor Trane would not be proud.
| Radiant ceiling heat? | bmargiotti | Inspecting HVAC Systems | 16 | 1/24/12 11:46 AM |
| Heat pump in a 80+ year old masonry house | jskrypka | Inspecting HVAC Systems | 9 | 11/25/06 11:47 PM |
| Carrier heat pump fires? | lprinzi | Inspecting HVAC Systems | 3 | 10/12/06 8:31 PM |
| Question on my heat pump | dbush | Inspecting HVAC Systems | 7 | 3/12/06 1:15 AM |
