Old 11/26/11, 10:51 AM
Stephen P. Shockley's Avatar
Stephen P. Shockley Stephen P. Shockley is online now
Default Heat Pump System Air Filter Returns
This may sound like a rediculous question, but it is for my own curiousity that I need to find out. If a house uses the square Air filters, does it make any difference in efficiency as to the orientation of the filters when being installed, except for the air flow direction on the filter itself? The reason I'm throwing this out there is that I'm wondering if there is a more restrictive flow of air if the filter is oriented with its v-grooves opposite the direction of the louvers on the return cover doors. I know the air flow direction is a no-brainer, just curious about the other.
Shore-Footed Property Services, LLC
Stephen P. Shockley
MD Licensed Home Inspector
410-726-3471
Salisbury, Md
Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/26/11, 12:58 PM
David A. Andersen's Avatar
Default Re: Heat Pump System Air Filter Returns
Every time the air changes direction, there are pressure changes.
So yes, but NO it does not matter.
It can't make any significant difference.
BPI# 5015804
Old 11/26/11, 9:05 PM
Thanks Dave. For some reason I thought I had seen some markings on a filter I used as a replacement at one time that not only marked the air flow but also was marked with top marking. Could be my imagination from the Tryptophan on Thursday...lol
Stephen P. Shockley
410-726-3471
Salisbury, Md
Old 11/26/11, 9:24 PM
Air flow, yes.
There is sticky stuff on one side of some filters and there are reinforcements to keep the filter from being sucked in if installed in the right direction.
BPI# 5015804
Heat pump thermostat jfunderburk Inspecting HVAC Systems 24 10/24/09 5:30 AM
Question on my heat pump dbush Inspecting HVAC Systems 7 3/12/06 12:15 AM
Massachusetts Board of Registration of Home Inspectors jtedesco1 Legislation, Licensing & Legal Issues for Inspectors 0 2/14/06 3:38 AM
Heat Pump Check list for inspecting dmacy Inspecting HVAC Systems 22 2/1/06 12:56 PM
