I was under the impression that heat pumps were prevalent in Florida. Talked to an HVAC technician today and he said not so. Don't assume anything. Look for the reversing valve in the high line coming out of compressor, otherwise it's a "straight cool" system in his words. Also, local codes prohibit any condensate drain lines from connecting to any drain pipe. They must all drain directly to the outside(primary and if there is one secondary). He also said on a typical replacement compressor the cost would be $900.00. If the homeowner had the whole unit replaced (including condensor coil) it would be $500.00. I assume labor not included, didn't ask. But he is not allowed to give this info to the homeowner. He is a tech and not in the sales dept.
Interesting. |
Without additional info I would take it as bar room talk
Heat pump or electric heat strips or nothing -- add one more thing - real furnaces and gas heat exchangers in out side HVAC units. Don't know if an HVAC tech can say what is the most prevalent His cost quotes are also subject to the same lack of documation bar room talk It might be all correct but -- Who knows rlb |
M1411.3 Condensate disposal. Condensate from all cooling coils or evaporators shall be conveyed from the drain pan outlet to an approved place of disposal. Condensate shall not discharge into a street, alley or other areas so as to cause a nuisance. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
There is a lot of gas in Fla (hot gas ???) !
You can tell if it is a heat pump by looking at the thermostat. The heat/cool switch has an EM Heat or AUX Heat setting. $900 is high (but true), $500 is B.S. ! |
Heat pumps are very prevalent around here, James and Chris. Remember too, that the Trane models don't always have visible reversing valves, they are often contained inside the cabinet.
You can sometimes see if the unit is a heat pump by checking the thermostat, but more than once the thermostat has been a heat pump model, and the system has been changed to electric heat and straight A/C. |
Around here if a home has a heat pump it can NOT be converted to a straight elec. furnace. If it is already an elec furnace and needs an upgrade it can be swapped out to either another straight elec furnace, a new heat pump or a gas furnace but never allowed to switch from Heat Pump to straight elec. (legally!) You can not always go by the thermostat as I have found more than one home with a Heat pump thermostat installed that did not have a Heat pump. Just be careful and check "every" location for some kind of confirmation that you do indeed have or don't have a heat pump. Heat pumps are extremely popular in NW Florida. Oh yeah, NO straight electric furnaces can be installed in NEW construction here. Check with your local HVAC companies to see what can and can not be done in your area.
| Home Inspector Listings | jbowman | Miscellaneous Discussion for Inspectors | 230 | 3/21/12 9:35 PM |
| Bungalows to Mansions Professional Home Inspection, LLC | bgraham | Miscellaneous Discussion for Inspectors | 7 | 1/11/09 3:03 PM |
| Insurance-scarred Florida emigres stream to Atlanta | jburkeson1 | Miscellaneous Discussion for Inspectors | 0 | 6/27/07 5:08 AM |
| Gainesville,fl Alachua county Home Inspection | bgraham | Miscellaneous Discussion for Inspectors | 0 | 9/1/06 11:22 AM |
| Radiant Heat Transfer | rmyers1 | Structural Inspections | 0 | 5/31/06 11:21 PM |
