Old 10/21/07, 9:37 PM
sfalvey sfalvey is offline
Default Is heat required???
I inspected a condo yesterday, the owner made some renovations, including adding a bedroom and a bathroom, the heat was never installed in either room. This may be a stupid question, but is heat required in either or both of these two spaces. I don't know if any permits were pulled or even required, I would imagine if permits were pulled, the inspector (great assumption) would have noted it.
Thank you,
Scott Falvey
Clear View Home Inspections, LLC
Newbury, NH
NACHI#05051292
www.clearviewhomeinspectionsllc.com
Old 10/21/07, 9:42 PM
ekartal6 ekartal6 is offline
Please Note: ekartal6 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Is heat required???
Bedrooms are required to have a heat source. If it's a half bath, a heat source is not required.
Old 10/21/07, 9:47 PM
It is a full bath.
The added bedroom is attached directly in line with another bedroom but does have a door between, I would assume the space still would need heat?
Thanks
Scott Falvey
Newbury, NH
NACHI#05051292
Old 10/21/07, 9:51 PM
Scott,
I will have to check. I'm pretty sure a vent is required in each room. In my local AHJ turf a heat source is required in any full bath.
Old 10/21/07, 10:06 PM
I my area a heat source is required in each habitable room. this includes all bathrooms, bedrooms, and even walk-in closets.
Old 10/21/07, 11:10 PM
Richard L. Bennett Richard L. Bennett is offline
In our area of Florida heat is not a large deal but is required. In most areas it does not say where or how but does say it must maintain all areas at a certain min temp.
Some BI's will accept a fire place. Portable heaters are not acceptable
As you can see I have spent too much time with the local BI
rlb
Old 10/21/07, 11:19 PM
bschumacher bschumacher is offline
In my area a heating source is required in all habitable rooms per Code. That includes all bathrooms and utility rooms as well as long hallways.
Old 10/21/07, 11:41 PM
Brian E. Kelly's Avatar
The bedroom needs heat or conditioned air.
Old 10/21/07, 11:51 PM
Jeffrey R. Pope's Avatar
That is the "norm" for most model codes. A habitable space requires a heat source. All other spaces are "not habitable" - closets, garages, storage/utility rooms, etc.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/25/07, 11:20 PM
Ron E. Perkerewicz Ron E. Perkerewicz is offline
Attached is the definition out of the International building code for habitable note that bathrooms are NOT habitable and would not require heat
HABITABLE SPACE.
A space in a building for living, sleeping,
eating or cooking. Bathrooms, toilet rooms, closets, halls,
storage or utility spaces and similar areas are not considered
habitable spaces.
Old 10/26/07, 12:56 AM
cbuell's Avatar
cbuell cbuell is offline
Please Note: cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Got to agree with Ron---Bathrooms are not considered "habitable" space according to the IRC. On the other hand I think heat in bathrooms is a real good idea.
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
Heat source required in bathrooms menser Inspecting HVAC Systems 7 7/13/06 12:57 PM
Emergency Lighting (commercial) mcyr Electrical Inspections 24 6/10/06 10:06 AM
Radiant Heat Transfer rmyers1 Structural Inspections 0 5/31/06 11:21 PM
