When is the temp. to hot to test the operation of the furnace for heat? I know below 65f for the A/C. Just wondering if the same goes for heat also.
Regards Gary "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
You can run a gas furnace at any temp.
If it is hot in the house already, the furnace may cycle. This should not be construed as a problem. The heat exchanger is getting too hot and the limit switch is cutting out. It will come back on in a few so long as the fan is running. |
Does anyone run the furnance, when the temps are high in the house, to check for heating function on the furnance?
Sure, just to be sure it fires.
| Inspection of HVAC by an area inspector. | dmcauley | Inspecting HVAC Systems | 13 | 3/21/07 11:03 AM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 8:17 PM |
| Radiant Heat Transfer | rmyers1 | Structural Inspections | 0 | 5/31/06 11:21 PM |
