Model # GLUA75-E3A
Serial# EB5D302F320107830 Looks like 2006 could be the age if they replaced it durring the flood Rick Kie |
Ricky, I think it is the same as: Rheem & Rudd & WEATHERKING Somewhere in the middle of the serial number will be a letter (typically F). The following four numbers are the week and year. In your case, 32nd week of 2001. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
For that type of serial number, how the digits are spaced is important. If it's spaced thusly: EB5D302 F3201 07830 then it's probably the 32nd week of 2001. However, the "B5" could also be February of 1985, 1995, or 2005. If there's a cooling condenser, check the date on that as well because they often are the same brand and similar codes and dates. Use other clues to help, too, such as a construction date of the home, a renovation date of the home, etc. NACHI 2005 U.S. Member of the Year
Russel
Here is a picture of the Furnace tag Rick Kie |
Russel, I've not seen what you describe.
I'm 99% sure that when the numbers/letters are all together like Ricky's picture it is indeed like I said: Somewhere in the middle of the serial number will be a letter (typically F). The following four numbers are the week and year. In his case, 32nd week of 2001. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
I have another one two If you could help me
Williamson Furnace built by Armstrong Armstong Model # G63-100D serial number looks like 32577 its hard to make out Rick Kie |
That's an odd serial number format but the explanation is directly above it: "Manufactured for H.C.I." With that information, whomever manufactured it left the spaces out of the serial number, so I would, indeed, go with F3201 as being the manufacture date.
I'll watch for it.
| Furnace Problem Comments Welcome | rfrost | Inspecting HVAC Systems | 28 | 10/21/07 6:26 PM |
| Sweating decision:Settle for lower SEER to use existing furnace? | Fel Randolph | Inspecting HVAC Systems | 2 | 6/6/07 2:56 PM |
| Armstrong Ultra 80 Oil Forced air furnace | Stephen Frazer | Inspecting HVAC Systems | 19 | 4/9/07 8:00 PM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 8:17 PM |
