Old 11/30/11, 2:56 AM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Heater duct insulation ...question
Insulation appears dirty on the ducting. Customer wants
to if there is an acceptable insulation that is covered with a plastic
jacket..like what I see on insulation in attics.
David
An Ounce of prevention is better
than a pound of cure :}
Need a home inspection in Alabama? Check out InterNACHI's listing of Alabama certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/30/11, 3:00 AM
Stephen W. Stanczyk's Avatar
Default Re: Heater duct insulation ...question
Most of the ducting you see in attics nowadays are flex duct with the plastic on the exterior. It is quite common to see sheet metal ducting with plain fiberglass wrapped around it. If they are going to replace the insulation, I would recommend they pookie all the seams before installation.
Stephen Stanczyk
Old 11/30/11, 5:13 AM
An HI An HI is offline
Please Note: An HI is a non-member guest and is in no way affiliated with InterNACHI or its members.
Is "pookie" a local term for "high velocity mastic duct sealer"?
Old 11/30/11, 8:58 AM
Charley L. Bottger's Avatar
David
I am telling my age here but that insulation was typically use on systems that had central heat only. A/C was added at a later date the insulation should have been updated with the addition of A/C
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 11/30/11, 9:40 AM
Jeffrey R. Pope's Avatar
Exposed fiberglass insulation over sheet metal duct was a common installation here in CA Charley. You will find this on original equipment (combination heating and cooling equipment) installed in the 70's, 80's and 90's. Most FAU's are now installed in attics for modern construction.
David - the insulation can be replaced, but this is really a "non-issue," other than being "ugly." As Steve suggested, the seams should be sealed to reduce this effect, or the insulation can be replaced with a foil-wrapped insulation.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/30/11, 12:11 PM
I always said Ca was back asward in what they do if ya see that kind of insulation in mid west it spells old even older than me
NACHI Member
State License # 130
Old 11/30/11, 12:43 PM
Brand name.
Stephen Stanczyk
Old 11/30/11, 12:51 PM
Robert Ernst Robert Ernst is online now
That hard pipe ducting is actually good to have. Sealing the joints is what is needed to reduce air leakage. The black on the insulation is from air movement. The fiberglass acts like a filter. If it is loose you can use some spray adhesive to secure it back to the duct. If this is in the garage and the drywall is being used for fire separation the insulation should be pulled out of the space between the drywall and the duct and be replaced with fire foam.
Nevada Inspector of Structures #1730
Nevada Energy Auditor #30
www.homecsi.com
Old 11/30/11, 4:25 PM
Gary D. Rowden Gary D. Rowden is offline
I agree with Jeff, I see exposed fiberglass insulation over sheet metal ducting quite a bit and is typically not a concern. It’s hard to tell for sure, but in this photo it appears that the ducting is resting up against the vent piping. I understand that the standard minimum air space clearance from combustibles for a type B double wall is 1”, and 6” for type C vent single wall, I also understand that fiberglass insulation is not considered a combustible material, but is this not a concern that it may be resting up against vent piping.
Old 11/30/11, 5:39 PM
Rick Strand's Avatar
Rick Strand Rick Strand is offline
Any vapor retarder belongs within the warmest third. If it is a heating duct then any plastic belongs against the ducting, not the exterior even though this looks better and is most common. This methedology takes on different forms depending upon the temperature of the air being ducted and the temperature of the air the ducting is running through.
Rick Strand, CPI
CAHPI Associate
Strand Home Inspections Inc.
Calgary, Alberta, Canada
Serving Calgary, Okotoks, Airdrie, Chestermere and Cochrane Alberta
Old 11/30/11, 7:25 PM
Thanks everybody for the feedback.....
Old 12/1/11, 3:40 PM
Here in Georgia, all ductwork insulation had to have some kind of vapor seal when installed (ie: Foil or vinyl) on ductwork in any surrounding unconditioned space. All sheetmetal ductwork joints must be sealed as well. In the late 60's and 70's I used Long fiber F/G insulation with foil backing, and all joints were wrapped with asbestos tape. By the 80's we were using a combination of Sheetmetal, Ductboard and flexduct. By the 90's, and going forward we used foil tape and/or mastic on all joints, and again all duct insulation should be vapor sealed. In any inspection I do, I would state that existing insulation of this type, and condition should be removed, joints sealed, and new insulation added to meet today's energy standards and requirements. IMHO
insulation question mnahrgang Exterior Inspections 5 1/25/10 4:48 PM
Insulation question Rick Vollmer Interior Inspections 12 5/4/09 6:31 AM
TPR & Combusiton Air thejnicki Plumbing Inspections 16 9/18/06 8:55 PM
