Anyone know anywhere or a good brand of tester to buy for heating system efficiency? I'm not really even sure what I'm looking for.
Rodney Misener, CMI Trinity Inspection Services Pictou County, Nova Scotia http://www.trinityinspectionservices.com Certified Master Inspector Certified Level 1 Thermographer Certified Energy Advisor WETT eCertified Inspector IAC2 Radon/Mold Certified Infrared Certified |
Bacharrach
Give me a call tonight. I have 2 kits- an older manual liquid type and a newer electronic. Would take too much time to discuss pros/cons on board. PS: No, I'm not writing a book!!! Last edited by Brian A. MacNeish; 2/1/09 at 9:14 AM.. |
Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
If you are looking for combustion Bacharach, Testo and TSI. But do not use the efficiency scale on the meter as that is for burner efficiency not furnace efficiency.
If you want something to determine BTU/HR capabilities in heating or air conditioning then look at the Testo 435-2 thru - 4 series meters. Has a jeweled micro fan anemometer and two wireless thermometers and Relative Humidity probes. Short story of the process you input the dimension of the return trunk drop on the meter, install a temperature probe in the return and the supply duct. Average the cfm in the return and the meter will calculate btu per hour for either cooling or heating. This winter it has really helped determining if a gas furnace is producing the heat it's supposed to. |
Remember you are not the HVAC man.
I check registers with my Infra red thermometer. Check the flue check flame check filter check gas lines check blower Check make up air supply Check anything visible that may be a problem and notate plate information,but it is not our job to size the thing, or play Licensed mechanical engineer. |
I am looking at offering furnace efficiency tests as an ancilliary service. Rodney Misener, CMI Trinity Inspection Services Pictou County, Nova Scotia http://www.trinityinspectionservices.com Certified Master Inspector Certified Level 1 Thermographer Certified Energy Advisor WETT eCertified Inspector IAC2 Radon/Mold Certified Infrared Certified |
Do you need an HVAC licence for that in your country?
I buy test equipment to determine what I need to know. You don't know what you need to know, so I'd just stand clear of that. Just my observation, short and sweet. I have worked for several mechanical contractors that had this equipment tucked back in the bottom of a closet. They put it there because even they don't know what to do with it. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
| New Washington Legislation Submitted | gdomagala | Legislation, Licensing & Legal Issues for Inspectors | 294 | 2/10/08 1:20 AM |
| Massachusetts Board of Registration of Home Inspectors | jtedesco1 | Legislation, Licensing & Legal Issues for Inspectors | 0 | 2/14/06 3:38 AM |
