attic mtd. 2.5 ton Armstrong “split system” heat pump.
) condensation drain pan: what can cause the pan to fill instead of the unit draining through the primary drain. there seems to be no “blockage” in the primary drain pipe.???
That is the answer there is something blocked, needs to be serviced by a HVAC Contractor
