Old 1/4/08, 12:43 PM
rnewman1 rnewman1 is offline
Send a message via Skype™ to rnewman1
Default HVAC in attic
Trying to understand why the pipe is taped closed. Any idea why this is done ?
Old 1/4/08, 1:15 PM
David A. Andersen's Avatar
Default Re: HVAC in attic
That is an auxiliary drain connection.
As the air-conditioning coil is attached to a gas furnace, the drain line is in a negative atmospheric pressure and draws unconditioned air into the equipment. It should be capped off.
Old 1/4/08, 1:17 PM
Barry Adair's Avatar
The primary and secondary drains are installed incorrectly should be trapped with secondary downward directed into the pan and they tape them trying to prevent air loss which filled traps should accomplish
Texas also requires insulation of the attic exposed condesate drainlines due to excessive heat and moisture in our attic
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Attic Access to HVAC equipment kweiss Inspecting HVAC Systems 15 9/13/07 9:19 AM
HVAC in unvented, spray foam insulated attic? lfreeze Inspecting HVAC Systems 17 6/20/07 9:58 AM
Access to Electrical Panel in Ontario by HVAC Contractors Nalliah Thayabharan Canadian Inspectors 10 5/21/07 3:01 PM
Spray Foam to the Rescue ? mcyr Structural Inspections 3 3/27/07 7:29 PM
