Old 1/22/12, 10:13 PM
Bob Elliott's Avatar
Default HVAC component needs ID
This is a standard gas operated HVAC unit mid efficiency about 5 years old.
Trying to identify what this thermocouple looking component is.
It is just below the A/C lines
Need a home inspection in Rhode Island? Check out InterNACHI's listing of Rhode Island certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/22/12, 10:51 PM
Chad Norlen, CPI's Avatar
Chad Norlen, CPI Chad Norlen, CPI is offline
Default Re: HVAC component needs ID
It's the remote temperature sensor for the thermostatic expansion valve (TXV), but it needs to be in intimate contact with the suction line to work properly.
In this position it would incorrectly determine that the superheat is way too high, and constantly flood the evaporator with too much refrigerant.
Chad Norlen
SEI Inspections
Certified Professional Inspector
HVAC Journeyman - State of Idaho
EPA Certified Universal Technician
Old 1/23/12, 1:22 AM
I see one end of the sensor going into the casing so could it be directly attached there inside?
I noticed so telltale green on the burners plate and suspected this sensor.
Where would this normally be seen as I have never Observed one in this location before ?
Old 1/23/12, 2:49 AM
Yes, it's attached to the TXV, which is what the discharge (high side, small tube) is attached to inside the casing. It's part of the cooling and has nothing to do with heat.
Because it is not mounted correctly and the evaporator is being flooded, I'm sure this area would get very icy when operating. The water dripping off the copper would account for the green.
Optimal location is as close as possible to end of evaporator, which is usually inside the casing, or is outside sometimes. If it is outside like this one, it should be insulated. You normally wouldn't see it unless you inspect the evaporator coil as part of your inspection.
heating-venting-air-conditioning-component-needs-id-txv-1-.gif   heating-venting-air-conditioning-component-needs-id-frozen.jpg
Chad Norlen
SEI Inspections
Old 1/23/12, 3:04 AM
Thanks Chad.
That helped me a lot to complete the report.
PLEASE HELP! Need to change the SOPs, per NEMA ktarasenko Electrical Inspections 76 4/19/10 8:15 PM
New Washington Legislation Submitted gdomagala Legislation, Licensing & Legal Issues for Inspectors 294 2/10/08 1:20 AM
Access to Electrical Panel in Ontario by HVAC Contractors Nalliah Thayabharan Canadian Inspectors 10 5/21/07 3:01 PM
Condemned Furnaces Spark Safety Issues Gary Reecher Inspecting HVAC Systems 7 3/8/07 8:17 PM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
