Hi,
I'm looking for the minimum clear area around a A/C condenser. For instance, between the condenser and house. Thanks most kindly, Corey |
2 ft
Two feet is typical.
Typical outside air-cooled A/C compressors require a minimal clearance around the unit to provide adequate air flow so that the condenser coils will be cooled efficiently. Air conditioning compressor/condenser units mounted too close to a wall, surrounded by shrubs, or multiple units located too closely together may not receive enough cool air flow to function properly. The result can be a shorter compressor life (expensive) and/or less efficient cooling operation (higher operation costs). I don't make a big deal if the unit is closer than two feet at the building side. |
Except when the service panel is against the house as well.
Then it is an electrical access issue. |
Depends on the manufacturer. Carrier has units that only require 12".
There were considerations that I was taught as a pup when choosing a proper location. If at all possible do not install on the west or south side of a structure: Do not install under the drip line of the roof as guttering may not always be present during the life of the structure and the overhanging soffits can create a recirulatory effect on condensers that have a upward discharge of the condenser fan. For structures that have no soffits simply apply the common sense rule.
If you see an issue with the installation of a condenser, simply write it up. It don't hurt writing up existing issues as you see them. |
| What is a 'condenser' dryer ?? | rcooke | Canadian Inspectors | 8 | 9/9/07 8:02 PM |
| Room size requirement for HVAC supply | kweiss | Inspecting HVAC Systems | 3 | 6/9/07 7:58 PM |
| Access to Electrical Panel in Ontario by HVAC Contractors | Nalliah Thayabharan | Canadian Inspectors | 8 | 5/21/07 4:01 PM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 9:17 PM |
