Old 12/21/06, 5:55 PM
sfalvey sfalvey is offline
Default HVAC Humidifier
Inspected a new home with a humidifier on the HVAC unit. I have heard humidifiers are not a great idea.
House is in New Hampshire, what are the pros and cons of using a built in humidifier?
Thanks.
Scott Falvey
Clear View Home Inspections, LLC
Newbury, NH
NACHI#05051292
www.clearviewhomeinspectionsllc.com
Old 12/21/06, 6:01 PM
Default Re: HVAC Humidifier
Properly installed and maintained a humidifier can be a good thing.
Everything --- people, furniture, pets, -- even rocks -- need humidity to some degree. In New Hampshire the cold air does not carry very much moisture -- the colder it gets, the less moisture in the air -- and it should be introduced into the house through a controlled humidifier of some sort.
The "con" would be a lack of care of the equipment --- read the instructions for care and feeding...
Old 12/21/06, 7:39 PM
ccbrands1 ccbrands1 is offline
Please Note: ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
like jae says, the only con is that most units are not maintained properly.
you turn it up in the winter, so the heat feels warmer
you turn it down in the summer, so the cool feels cooler
Old 12/21/06, 7:45 PM
Charley L. Bottger's Avatar
You turn it off in the summer you sure don't want to add any water to cool air the A/C unit is trying to dehumidify.
Old 12/21/06, 8:22 PM
David P. Valley's Avatar
Attachment 7911
Old 12/21/06, 8:44 PM
Fer sher, fer sher...
Old 12/21/06, 10:04 PM
Great Info. guys, thanks.
Scott Falvey
Newbury, NH
NACHI#05051292
Do you report Age of HVAC equipment? dandersen Inspecting HVAC Systems 59 8/15/09 10:13 PM
Room size requirement for HVAC supply kweiss Inspecting HVAC Systems 3 6/9/07 7:58 PM
Access to Electrical Panel in Ontario by HVAC Contractors Nalliah Thayabharan Canadian Inspectors 8 5/21/07 4:01 PM
Condemned Furnaces Spark Safety Issues Gary Reecher Inspecting HVAC Systems 7 3/8/07 9:17 PM
