I have a situation on an inspection I did today I need some help with. The homeowner stated that the air flow from the registers in some rooms is stronger than others. When I got to the house and went in the attic I discovered multiple problems with the ductwork; crimped piping, improperly installed support straps, branch distribution laying over the return pipe, etc. Overall the system is a mess and could have been arranged better. There are 2 returns going into the attic unit.
My question is in the ductwork from the main ceiling return going into the unit is about 35 ft long. I've never seen one this long before. What generally is the appropriate distance for this? I have attached a photo of the attic. |
I have no idea. I'm not a system designer. Refer it out if you believe there is a problem.
You have all kinds of imporper bends in those ducts. Go to the Air Difussion council - they give you the standards for duct installation.
Like Larry said, get a local HVAC contractor out there to sort it out.
No 35 feet is not an excessive run for a return air see them that long all of the time matter of fact I installed a longer return air run than that in my own house this last summer works just great. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Just wondering as I do not think it would effect some and not others. It would just be weaker overall from my understanding. Did you trace the weaker register ducting from the attic to see if it was bent? |
I do not calculate either, but seem to recall (little off subject ) that it is 10 feet added for each bend, correct? How much of a factor is the blower on the unit.Yes I see what you are saying though. |
The size of the blower is very important must move the proper CFM to maintain Duct static pressure don't you mean 10 feet taken away for each bend not added BED time for this old man hard day tomorrow Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Yeah I am reminded of the return above the supply vent in that redneck DIY presentation. Always gets a laugh when I do the homebuyer seminar.. |
Thanks for the responses everyone. I used an infrared camera to get a visual picture of the air flow from the registers in each room and then traced each room from the register back to the source. The lines toward the front of the picture had good flow, but the lines closest to the unit with had the bends had significantly less air flow. Some had next to none, as you barely see the register in the infrared photo. I concluded from this that the air was attempting to branch out but the obstructions (bends, crimps, etc) were forcing the air back down the supply line to the other rooms. Generally, the farther away you go with the supply, the lower the air flow, but this was just the opposite. And yes you are correct in that I wanted to know if length of the duct from the return to the unit was part of the problem and if I should cite it as well as a contributing factor to the problem. She had a HVAC tech look at it and he said it should be shorter, but she wanted an independent opinion. And I really did not know, but I had never seen one that long in an attic before. Most HVAC techs install the unit in the middle of the attic close to the return but this one was not done this way. I am siting the location of the unit as undesirable due to the fact you can't get to the backside of the unit.
There is a second return also feeding into the unit from the garage bonus room. It is about 20 to 25 feet long. Is there a maximum length for flex duct here? Is this considered improper? |
Using spiral round or flex duct adds about double the resistance to airflow as the same size of smooth galvanized pipe. e.g. If you need 6" pipe to supply/exhuast an area properly and you're using a flex duct, increase the diameter by 1" to ensure adequate airflow. In other words, the 7" flex is like using 6" smooth. Residential duct systems in general are some of the worst designed (non-designed!!) parts of houses. Studies have shown that from 20-40% of the air moving through the air handler/fan, does not get to or from the rooms it was designed for due to duck leaks. |
Can you tell me the diameter of the main trunk line I can see at least 4 take offs on it in the pic how many taps on the supply plenum or was the whole home being fed from one trunk line
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 36 | 10/27/10 11:21 AM |
| Pellet stove help | chellickson | General Inspection Discussion | 23 | 8/19/10 2:23 AM |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 9:16 AM |
| Identify ABS defective pipe | mcyr | Plumbing Inspections | 6 | 1/29/09 7:39 PM |
