| HVAC Topics include heating, venting, and air conditioning. |
I'm bringing this over here for future reference...
HVAC AGE CODES IN SERIAL # INFO Amana: BLACKHORSE. B=1971 or 1981. (Of course, now that they've been bought by Goodman, who knows what'll happen.) BARD 1962 to March 1980 Sample Number 123456 A D 1st six digits are the Unit Identity Number. In this example they are represented by the numbers 123456. 7th digit is the month of Manufacture. (The letter A in the Sample represents January). A = January B = February C = March D = April E = May F = June G = July H = August Letter “I” was not used. J = September K = October L = November M = December 8th digit is the year of Manufacture. (The letter D in the Sample represents 1964). 1962 = B 1963 = C 1964 = D 1965 = E 1966 = F 1967 = G 1968 = H Letter “I” was not used. 1969 = J 1970 = K 1971 = L 1972 = M 1973 = N 1974 = O 1975 = P Letter “Q” was not used. 1976 = R 1977 = S 1978 = T 1979 = U 1980 = V Bard April & May 1980 Sample number 123 D A 123456 1st three digits are the Compressor Part Number. 4th digit is the month of Manufacture. In this sample D represents April. D = April F = May 5th digit is the year of Manufacture. In this sample A represents 1980. 1980 = A This serial number style was only used during the months of April & May 1980. 6th thru 11th digits represent the Unit Identity Number. Bard June 1980 to Current Sample number 123 H80 1234567 02 1st three digits = Compressor Part # 4th digit = Month A = January B = February C = March D = April “E” was not used F = May “G” was not used H = June “I” was not used J = July K = August L = September M = October N = November “O” was not used P = December 5th & 6th digits = Year 80 = 1980 81 = 1981 82 = 1982 right on thru. The year 2000 started the numerical numbering from 00. 00 = 2000 01 = 2001 02 = 2002 right on thru to current date. 7th thru 13th digits = Unit Identity # 14th & 15th digits = Factory Code (01=OH; 02=GA) Carrier, Bryant, Payne, Day & Night: Recently (last 20 years or so) the first four numbers in the serial number represent the week and year. Previously, it was a complex series of letters and single digits. Call 905 672-0860 if you get stuck. Coleman: Serial numbers prior to April 1992=1st two numbers are month, then year, then series. After April 1992, 1st two numbers are year, then month, then series. Comfortmaker (International Comfort) uses the first letter for the month (skipping I) and the first two digits are the year. First Company Service Parts is one of 4 divisions of First Operations. They supply OEM equipment to all of the major HVAC manufacturers. They are located in Dallas, Tx at 214-388-5751. Harold Hammer at Tech Support (ext#5) will answer your questions. Goodman: First two digits of the serial number are the year. Second two are the month. Btu rating is model number..ie; GMP075-3 (75,000 bonnet input) Compressor is same :serial # 9709088872 (yr1997 wk 09) Tonnage is model # CK361C The first two numbers after the CK (letters) divided by 12 is tons. ie: 36 div by 12= 3 tons. Lennox: Either the first two or second two digits are the year, it varies by era, but most of them actually have a separate sticker somewhere that has the year printed on it. Newer ones are first two equals manufacturing plant #, 2nd two are year and letter in fifth slot is month (A thru M minus I). So 5898G 07568 would be Plant # 58, Year of MFR would be 98 and month would be July. Rheem & Rudd: in the middle of the serial number will be a letter "F" the following four numbers are the week and year. The first letter of the serial number gives the year of manufacture as follows: TRANE Trane uses alpha codes in their serial numbers to determine year of manufacture. They started this in 1987 with the letter B and skipped a couple of letters during the years........ The first letter of the serial number gives the year of manufacture as follows: In 2002 they started their serial numbers with the year it was built. In 2002 the first character of the serial number is 2, in 2003, 3 and so on. Z=2001 R=2000 P=1999 N=1998 M=97 L=96 K=95 J=94 H=93 G=92 F=91 E=90 D=89 C=88 B=87 S=86 Y=85 X=84 W=83 U=82(seventh digit) T=81(seventh digit) O, A=80(seventh digit) YORK (Unitary Products since 1984) Note: they skip the letters I, O, Q, U, Z. Year of make indicated by 3rd letter in the serial number. Fraser, Johnston and Luxaire were purchased by York in 1980. 1971 - A 1972 - B 1973 - C 1974 - D 1975 - E 1976 - F 1977 - G 1978 - H 1979 - J 1980 - K 1981 - L 1982 – M 1983 – N 1984 – P 1985 - R 1986 - S 1987 - T 1988 - V 1989 - W 1990 - X 1991 – Y 1992 – A 1993 - B 1994 - C 1995 – D 1996 - E 1997 - F 1998 - G 1999 - H 2000 - J 2001 - K 2002 - L 2003 - M 2004 - N 2005 - P 2006 - R 2007 - S |
Thanks, Dave. I was just redoing mine...this is faster.
Good job, Dave.
I thought about doing that, but thinking always gives me a headache. It's a good thing you're around. "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
Bill,
It would be great if you could post your Bradford White (and any other water heater) information that you may have, in the Plumbing forum. |
Thank's for the info Dave!
"Technical Reference Guide"
Published by Carson Dunlop Weldon & Associates, Toronto, 2001 ISBN 1-895585-90-2 http://www.carsondunlop.com This is exactly why we need to sort through the archives, pull out all the reference materials, and publish them somewhere. http://www.nachi.org/forum/showthread.php?t=95 |
Here are a few more--
Weil-McLain Please look on the outside jacket of the boiler for a CP Serial Number. It will have a bar code on it. Call (or email) Wiel McLain and they will tell you the date of manufacture. Phone: 219-879-6561 ask for Technical Services Peerless Prior to 1984 there was not a date code included as part of the serial number. Starting in 1984, there was a four digit date code following the serial number that was month and year. Example – JO-12345-1084, this unit was built in October of 1984. Starting in the year 2000, same idea only it was a six digit date code following the serial number that is year and month. Example – 1234567-200105, this would have been build in May of 2001. Anything without the addition to the serial number would have been made before 1984 and would require contact with the factory. "A man cannot be truly grateful and remain unhappy"
http://www.SmithHomeInspection.com SmithHomeInspection@yahoo.com NY State Lic. # 16000008304 631-434-5200 |
Can anyone help me date a Frigidaire model FS3BA, serial FS3000752901 ?
July 2000
Please note Rheem & Rudd: as follows... is missing info below
Help anybody ? |
Rheem or Ruud Capacity: Look for those elusive two digits in the model number (usually, but not always) divisible by 6 and divide by 12 to convert to tons. Example: RPGC-037JA = 3 ton Age: Four digits of serial number indicate date of manufacture where first two indicate the week and the third and fourth are the year. In the 1960s and early ‘70s this was the last four digits. More recently date of manufacture information is found closer to the middle of the serial number. Example: xxxx1872 = 18th week of 1972 |
11111F187211111 Sometimes you'll find nice spaces mixed in there: 11111 F1872 11111
| Access to Electrical Panel in Ontario by HVAC Contractors | Nalliah Thayabharan | Canadian Inspectors | 8 | 5/21/07 3:01 PM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | HVAC | 7 | 3/8/07 8:17 PM |
| Appliance Manufacture Dates | bayside | General Inspection Discussion | 1 | 7/1/06 12:01 PM |
| Help with HVAC dates | jsmith3 | HVAC | 5 | 3/2/06 12:46 AM |
| Singer HVAC dates? | jsmith3 | HVAC | 3 | 1/27/06 8:43 AM |
