I think perhaps I will start offering a new side to my inspections by offering the home owners a post inspection after installation by Hvac contractors. After two of my inspections this week can see a great need in this area for this as the city inspectors are not doing their job if a permit was even obtained which it probally was not.
I just came off an inspection this afternoon that the contractor should have his license pulled. The house old two story renovated for a flip. The thermostat within 5 feet of the kitchen stove two returns one above the stat and one below, both wall mounted close enough to the kitchen stove to be used for a stove exhaust fan I encounter bad installs like this very frequently and have been considering adding a post inspection for the consumer before they pay the contractor good money for bad work. What do you think would it work or would I just piss off all of the contractors that do good work??? </IMG> Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
bandag is a non-member guest and is in no way affiliated with InterNACHI or its members.
The "good" contractors wouldn't be pissed off if they did everything to code, it's the fly by nites that would be pissed and they probably should change careers anyway!
bbenjamin is a non-member guest and is in no way affiliated with InterNACHI or its members.
Sounds like a good idea to me. It gives the consumers you serve a little more assurance that they are getting a quality air conditioning install and that it will provide adequte heating and cooling for years to come. I would also check to see what professional org's these hvac contractors belong to. If you need any additional info feel free to send me a email or a private message.
Charlie, That is what got me inspections at any cost for the past 11 years and got me into this business. "Anyone can inspect a house... Not just anyone can do the HVAC" (from the realtor that got me doing this job).
1. Being able to run HVAC equipment at low ambient temps is a major plus to clients. You know how to modify equipment for low ambient use! 2. Refrigerant pressures tell it all. 3. Air flow issues = comfort/discomfort. 4. Electronic leak testing. Go for it! You'll be glad you did. Dig out that EPA certification card and post it with your NACHI badge and State Licence. |
I just get so tired of contractors taking advantage of little old ladies and and folks that won't crawl under a home and check the quality of work on a new install the contractors the bad ones know this and do just anything they want to do just so long as they get their check. I see this kind of work all the time. If these A** Holes knew they were not going to be paid until after the work was inspected they might change the quality of work performed. City inspectors in this area will not crawl the crawl space and check duct work and you know your self what a bad duct job will do to the performance and the economics of operating a bad system Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Do you guys ever think about doing a quick acid check if things point in that general direction?
Charley,
Yep, there's been more than one occasion Ive been tempted to do one. I keep the kit in my truck along with a stubby hose and gage but I have only done it once for an inspection and it was for a friend of mine. He was pretty much convinced the unit was a POS anyway so he wanted me to do it. It turned out to be contaminated. As you probably know it only takes a couple minutes to perform one with the glass bulb kit but the information is very valuable. |
It is amazing how many friends you can have when you know how to do something not everyone can do. Doing that 8-to-10 hours a day I don't want my friends calling me for freebies. At my age you have to be a front line relative to get me to look at an A/C I am what you call a burn out. I just tell everyone I sold my tools. Is that called embellishing. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
I hear that.
I carry litmus paper (commercial type) and test the oil that comes out when I take my gauges off. The others are a bit expensive and getting oil is sometimes difficult in the summer.
Using a megometer on the compressor is a good indication of contaminants in the oil/refrigerant also.You must be careful as this is starting to get close to " predicting the future". I simply report on what the meter says and let the client make any further decisions. |
I use the hoses on my gages that have the check valves as required by the EPA. Don't want the Freon Police to arrest me </IMG></IMG> Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
I was never a fan of flushing. The R-11 flush was out the window when I arrived on the scene.
Yes, the acid test will help you determine the extent of suction line dryers needed. I did use acid neutralizer additives in very large (10 hp and above) compressors, which appeared to work quite well. Never had any callbacks related to contaminants. Acid neutralizer and suction line dryers is about the extent of cleanup that I was comfortable with. Yes, those hoses are required. However, in the cool weather I usually still get a shot of oil coming pass the Schrader valve when I remove the gauges which I can acid test. If the oil really stinks or its an excessively old unit which the client is dependent upon and does not intend to replace in the near future, I recommend this procedure to give them a little better idea of the existing condition of the equipment. |
I never really thought about an acid test on these old systems but sounds like something that I might charge a few extra bucks for. I alway have known that two heads were better than one. Thanks Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Just another little extra service to make you client happy!
And another way to get your inspection fees is up where they belong! |
| Access to Electrical Panel in Ontario by HVAC Contractors | Nalliah Thayabharan | Canadian Inspectors | 10 | 5/21/07 3:01 PM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 8:17 PM |
| Good advise on why NOT to discount. | gmendes | Miscellaneous Discussion for Inspectors | 5 | 11/3/06 9:40 AM |
| List Your Business For Free | jbowman | Miscellaneous Discussion for Inspectors | 17 | 8/13/06 12:29 PM |
