Old 8/13/11, 12:48 PM
John Harrison's Avatar
John Harrison John Harrison is offline
Default HVAC Plumbing
Can anyone tell me why these lines have this section installed in it.
These are the Fresh air and exhaust lines to the furnace.
Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas
Active Rain Member
Need a home inspection in Wyoming? Check out InterNACHI's listing of Wyoming certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/13/11, 1:03 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Default Re: HVAC Plumbing
To muffle the sound of most lennox pulse furnaces.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 8/13/11, 1:36 PM
David A. Andersen's Avatar
Yup.
BPI# 5015804
Old 8/13/11, 1:43 PM
So no problem with the installation then??
Thanks guys.
Active Rain Member
Old 8/13/11, 7:49 PM
KEVIN WOOD's Avatar
Correct
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 8/14/11, 12:18 PM
Robert J. OConnor's Avatar
If thats the venting for a Lennox G14 or GSR14 series pulse furnace, there have been a history of problems with cracked heat exchangers. Those need evaluation by a specialist.
http://www.inspectapedia.com/heat/lennox1.htm
File Type: pdf Furnace - Lennox Pulse G14 Muffler Installation.pdf (162.5 KB, 129 views)
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 8/14/11, 1:25 PM
I was unable to verify the date aside from a sharpie marking dating for March of 1983.
Due to a low output of heat from the registers. A temp diff of 6 degrees on both heat and cool cycles, and an unknown last service date.
I recommended a full system evaluation by a licensed HVAC tech before further pursuit of purchase.
Active Rain Member
Old 8/15/11, 10:20 AM
You can get a 6° temperature difference just because the duct passes through the attic or crawlspace.
I don't think anything was working.
BPI# 5015804
Old 8/15/11, 6:55 PM
Michael Larson's Avatar
Lennox Industries Inc., the maker of Lennox Pulse furnaces, announced it has set up a free program to inspect Lennox furnaces installed from 1982 to 1989 to check for carbon monoxide leaks or as the company stated: "because of "increased instances of corrosion in some Pulse furnace heat exchangers in units installed before 1990."
Please inform your client as these can be a very real safety hazard.
More info:
Michael Larson
Hudson, WI
Hummm Plumbing or HVAC issue? mmixson Plumbing Inspections 4 6/4/10 11:08 PM
HVAC and Plumbing courses gkoehl Inspection Education & Training 1 10/20/06 6:01 PM
A few useful posts - I forget from whom jmichalski Plumbing Inspections 12 3/30/06 9:06 PM
