Old 10/9/07, 8:09 PM
Charley L. Bottger's Avatar
Default HVAC question for the seasoned HI
I have a serious question for a change.
As an HI not a HVAC person what would you consider as your #1 concern about an attic installed central heating and cooling system and lets discount the fact if the unit operates from the stat or it does not. I have a reason for asking this question lets just see where it goes.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 10/9/07, 8:15 PM
Bob Elliott's Avatar
Default Re: HVAC question for the seasoned HI
My first thought is insulation ,or lack of.
Old 10/9/07, 8:20 PM
Jeffrey R. Jonas's Avatar
Condensate drain
Old 10/9/07, 8:43 PM
Richard L. Bennett Richard L. Bennett is offline
Preventive maintance
rlb
Old 10/9/07, 8:50 PM
Yes, it may be like, in our area, having a furnace in a crawlspace. The ones I inspect typically have dirty filters and the owners are unaware.
Larry Kage, CMI
231 929 3525
Old 10/9/07, 9:20 PM
Well we have had 25 lookers and I guess 4 seasoned HI's respond only two with somewhat similar answers Hope I get more answers but I guess all of the CMI'S are hunkered down in their meeting.
NACHI Member
State License # 130
Old 10/9/07, 9:26 PM
Bruce A. King's Avatar
I have no concerns with a properly sized and installed system.
I have two in my attic (split system heat pumps).
Best system I have found yet. No dirt in the ducts, good even airflow etc.
I might add the fact that these are Seer 13, variable speed airhandlers that have overall selectable airflow and also have duct dampers to fine tune small rooms. Attic is also large, well ventilated and allows for easy service.
This is mainly a cooling climate and your mileage may vary in a heating climate where you want warm air discharging next to your easy chair.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 10/9/07, 9:32 PM
Bruce I am not asking if you like or dislike an attic installed system my question is what is your # 1 concern when you as an HI are inspecting an attic system for a client.
NACHI Member
State License # 130
Old 10/9/07, 9:49 PM
Steve Taylor Steve Taylor is offline
I would check to see that the unit has a pan under it with either a float switch on the pan or a secondary condensate disposal line. Also, that there is a diconnect for the unit. a clear floor area for access and maintenance, a light, and a GFCI protected outlet for maintenance/service as well as the usual stuff.
Old 10/9/07, 9:56 PM
My main concern is to not miss anything. Too many items to list and all are important. Strange question there Charley, you better have a good reason for asking that.
704 301-3207
Old 10/9/07, 10:01 PM
Joseph Hagarty,  CMI's Avatar
There are several concerns. In no particular order....
- Attic Ventilation. Temperature of the environment containing the air handler and distribution ducts.
- Accessibility. Routinely a problem with attic mounted systems.
- Condensate Recovery. Handling and where it is terminating.
- HVAC Duct. Type materials. Damaged areas of HVAC duct or disconnected (not installed). Damage and incomplete installations are more common in New Construction from our experience.
- ETC....
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 10/9/07, 11:47 PM
This is my # 1 concern when I first enter the attic I look for the drain pan always first; not to say there are not plenty of other concerns with just importance but the drain pan is the first I look for.
The reason I even bring this up is I performed a mold inspect today on a home that just had a full house inspection by another inspector. Not me.
I was poking around in the attic looking for mold from a roof leak and low and behold there sat the furnace no DRAIN pan. The buyer was present for my mold inspection So I casually asked him if the drain pan for the A-coil was going to be installed as part of the contract. He gave me that blank look and stated he did not know what I was refering to as he did not read in his inspection report anything about a drain pan on the furnace.
Me thinks I stuck my foot in my mouth I think I can already smell the stink.
I was just making casual conversation and did not have any idea that another home inspector would not place any importance on a missing drain pan. But on the other hand only a couple of post from above mentioned condensate as their # 1 concern. I can honestly state That if a ceiling gets wet after one of my inspections it will not be from a missing drain pan. Ok guys have at it that was the reason for this post.
NACHI Member
State License # 130
Old 10/10/07, 12:01 AM
Jeffrey R. Pope's Avatar
Yep. Pans are important. . .
heating-venting-air-conditioning-question-seasoned-hi-p8310002.jpg   heating-venting-air-conditioning-question-seasoned-hi-ir_0185.jpg   heating-venting-air-conditioning-question-seasoned-hi-ir_0186.jpg
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/10/07, 12:46 AM
You are probably 100% correct.I just typed the first thing I would have noticed.
Good post.
Another concern is filter access as far as maintenance for the client.
Old 10/10/07, 8:06 AM
Scott Byrnes's Avatar
Scott Byrnes Scott Byrnes is offline
Yes, pans are important. Being the #1 major concern, maybe. But there are so many different things to check, I'm thinking #1 major concern is to assure there is an air handler.
Because there is no pan, you made the right call pointing it out no matter how you phrased it. What you don't know is if the inspector the client used did report the lack of a pan and the client just didn't bother reading the report. Or was told about it and didn't bother giving it any further thought.
I had a client call me to do another inspection for them and she requested that I check the GFCI outlets in the bathroom to assure they are working properly since they weren't working properly at the 1st house I inspected for them. I looked up the old report and there it was under the bathrooms,"GFCI outlets not working properly...".
Need HVAC pro's for question bdoles2 Inspecting HVAC Systems 4 8/1/07 7:12 PM
Access to Electrical Panel in Ontario by HVAC Contractors Nalliah Thayabharan Canadian Inspectors 10 5/21/07 3:01 PM
Condemned Furnaces Spark Safety Issues Gary Reecher Inspecting HVAC Systems 7 3/8/07 8:17 PM
Commerical HVAC code question sbyrnes Inspecting HVAC Systems 19 11/15/06 10:08 PM
