Old 3/25/09, 5:21 PM
lprinzi lprinzi is offline
Default HVAC return with fresh air?
Did an inspection today on a brand new townhome, and ran across a new installation of a heat pump with a return duct running from the coffin box enclosure, up through the attic and pulling air from the rear exterior patio. I'm not familiar with an installation like this. Has anyone heard of new installations here in Florida that are pulling return air from the exterior?
Lou Prinzi
First Choice Building Inspections, Inc.
www.FCBIJax.com
(904) 223-0068
Find an InterNACHI certified New York Home Inspector (and anywhere else in North America)
Old 3/25/09, 5:40 PM
Charley L. Bottger's Avatar
Default Re: HVAC return with fresh air?
Doesn't matter if you are in Florida or Alaska the return is normally a closed loop unless there is a damper installed to allow the outside air to be closed when necessary or perhaps if the unit is over sized to accommodate the extra load. What was the SQ footage of the town home and what was the tonnage of the unit.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 3/25/09, 5:44 PM
Heat pump is 3.5 tons and it has 1536 sq ft. I've never seen or heard of anything like this so I thought it might be some new design.
Lou Prinzi
www.FCBIJax.com
(904) 223-0068
Old 3/25/09, 7:27 PM
Your tonnage and Sq footage are a close match for the humidity down there.
If it was me I would red flag the outside air and require the contractor to explain his supposed theory provided there is no damper installed.
BTW lets call a plenum a plenum not a coffin but I knew what you were talking about I am just ribbing you.
NACHI Member
State License # 130
Old 3/25/09, 7:47 PM
Thanks for the info Charlie. I already wrote up the report and suggested the contractor explain the why-for's. There is no damper as far as I can see either. I'm interested in hearing what the contractor says.
Lou Prinzi
www.FCBIJax.com
(904) 223-0068
Old 3/25/09, 10:21 PM
Wayne B. Wilson's Avatar
It sounds like a Fresh Air exchanger to me Are you sure it isn't one
Old 4/15/09, 5:24 PM
It is a fresh air return. However, in 12 years of home inspecting, I've never seen one installed in a heat pump system. Was wondering if this is something new or what.
Lou Prinzi
www.FCBIJax.com
(904) 223-0068
Old 4/17/09, 4:17 PM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
No not something new but it should have a weighted barometric so that it is only pulling so much fresh air. Other wise it will be way overpressurizing the building.
Old 4/20/09, 10:08 PM
Lou
A 3.5 ton Heat Pump system on 1536 sq.ft. seems a little heavy for a Brand New Townhome. I'm sure it is built to "Green/Energy Star" standards based on today's standards and codes environment. Also, it is in Florida...right ?
That being said... I still see fresh-air installed through the R/A system on occassion in my area, although usually on gas heat w/A/C or dual-fuel/piggyback systems. I can't remember when I last saw this design on a staright up Heat Pump systen. The ones I have seen lately have had manual dampers or small motorized dampers controlled with inline humidistats, similar to commercial Economizers w/ enthapy controlled operation.
I check the functionallity, and note this unusual design to my clients as possibly/probabley needing increased monitoring/maintenance/service.
I like the design idea on residential systems, and if installed and setup properly, I think can be a great energy saver as well a improving the IAQ of most settings.
The key...installation, setup, maintenance, and monitoring.
IMHO
Old 4/21/09, 6:41 AM
I would rather have a controlled amount of fresh air that I could condition and pressurize the building than having air leaks all over the home.
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
HVAC length of pipe from return hmiles Inspecting HVAC Systems 17 11/7/08 11:24 AM
HVAC Design - Air Return jhaynes Inspecting HVAC Systems 9 9/16/08 7:52 PM
Access to Electrical Panel in Ontario by HVAC Contractors Nalliah Thayabharan Canadian Inspectors 10 5/21/07 3:01 PM
Condemned Furnaces Spark Safety Issues Gary Reecher Inspecting HVAC Systems 7 3/8/07 8:17 PM
