Whats all involved in a salt test? Is it more than a visual inspection of the heat exchange and CO test?
I believe a brine test is one type of test for determining if there are cracks in a certain shape/type heat exchanger.
Yes, it is more than a visual and more involved than using a CO meter. |
A salt spray test is a test for heat exchanger cracks, Its conducted by disconnecting the blower motor power wire so it will not run. The warm air plenum is opened for access. Water & salt mix is sprayed into the burners when on and a propane torch is passed over the area above the heat exchanger in the plenum, salt will pass through the crack and the blue propane flame will turn orange.
This can only be used on older 60% efficient or less furnace, it can not be used with any furnace that is a power Vented John Rupert Accurate Property Inspections Solitaire Heating & Cooling CSG Training (HVAC Training & Consulting) |
Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
The Gas Research Institute does not recommend or indorse the salt spray test because it causes corrosion. The methane/nitrogen mixture gas test is their approved method.
This test was common 20+ years ago, it still can be used by an hvac company when they are pretty sure the furnace is cracked and will be changed out, I ran across a few hvac companys using this test this winter.
Ditto Jay
Gary Porter GLP's Home and Mold Inspections 321-239-0621 Certified Commercial Mold Inspector Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford Orange County, Seminole County, Volusia County, Osceola County www.homeandmoldinspections.com |
rmyers1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
There are many other ways of visually checking for cracked heat exchangers. Suggest keep it visual, visual, and visual. |
tneumann is a non-member guest and is in no way affiliated with InterNACHI or its members.
Add some Baileys to it..that will slow you down more to our speed..thank you.
| Moisture in slabs | mcyr | Structural | 7 | 8/20/07 7:33 PM |
| bbbb | mcyr | Structural | 1 | 8/19/07 10:26 PM |
| Test HVAC | dmccauley | HVAC | 8 | 4/12/06 10:30 AM |
| HVAC Salt Test | jford | Legislation, Licensing & Legal Issues | 0 | 4/3/06 11:38 AM |
