During an inspection today, I used the thermostat to start the A/C for a few minutes at 60 Degrees F. I do this to see if the compressor fires, not to test the temperature differential. After a minute or two, the circuit breaker tripped off, it is my understanding of A/C principals that the compressor should not be run for a long time at low temperatures and that a short test like this will not run HIGH amps and should not trip the breaker? Any input from a A/C guru?
Thanks George |
| Need a home inspection in Washington? Check out InterNACHI's listing of Washington certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I am not a AC guru. That should not happen. Defer the system to a
HVAC contractor. Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
Thanks
A tripping breaker is an indication of a failing compressor. . .
Put a little oil and liquid refrigerant on top of that compressor piston and watch the amperage go up!
Do you know what a low ambient control is? You may have locked up the compressor. Locked rotor average tends to trip circuit breakers. Anyone testing air conditioning under low ambient conditions, I highly recommend that you do it from outside the house, not at the thermostat. You can turn the circuit breaker off when you hear the compressor about to jump out of the condensing unit. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
The compressor crankcase heater may have failed and the refrigerant migrated to the compressor oil. Start up under that condition could lead to compressor pulling in foaming oil and locking up.
Not many a/c units have a crankcase heater!
It costs too much! Only Heat Pumps do. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
my question why even take the chance?
good input thanks to all. george
He didn't say it was a Heat pump. He said it was an HVAC which leads me to believe it was a standard air conditioner which does not have an accumulator (heat pumps do).
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
I live in a cool/cold climate. Just about everything I see up here is HP/AC.
Somebody thinks so.
What's your point? Please enlighten me as to what a low ambient condition actually is... I happen to be from the South (at this point in my life) and it gets down to about 21° at night and up to 60 during the day. Do you think this is okey-dokey to run an air conditioner at 10 o'clock in the morning when it reaches 60? 70 psig is the design operating temperature for R-22 refrigerant. What's the saturation temperature at this pressure at atmospheric conditions at sea level? Now please enlighten us as to what the saturation pressure is at 32°F for R-22 refrigerant. What's the pressure difference? Does a freezing evaporator coil not potentially cause refrigeration slugging? At what outdoor temperature does refrigeration pressures on the high side fall to a point where the back pressure falls below the freezing temperature? Don't tell me it depends on the equipment. Is it just slightly possible that cool outdoor air and no load in the house may cause a "low ambient condition"? Please keep in mind that no one here is required to be certified to put a set of refrigeration gauges on an air-conditioning unit. Please explain how everyone here will know when a low ambient condition exists without installing a set of refrigeration gauges!? "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission Last edited by dandersen; 3/19/10 at 3:19 PM.. |
The breaker tripped because of a system problem, not an inspection problem. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
| Testing HVAC if Temperture is below 60 degrees | dnasser | Inspecting HVAC Systems | 4 | 4/14/09 12:44 AM |
| Well Water Testing in Coeur d’Alene, ID 83815 | rspriggs | Ancillary Inspection Services & Additional Topics | 0 | 1/9/09 4:31 AM |
| Moisture in slabs | mcyr | Structural Inspections | 7 | 8/20/07 8:33 PM |
| bbbb | mcyr | Structural Inspections | 1 | 8/19/07 11:26 PM |
