Old 12/16/08, 1:53 PM
Vince Santos's Avatar
Vince Santos Vince Santos is offline
Default HVAC Tools
Anyone use a type of camera that allows you to look into the furnace heat exchanger area? I'd like to be able to get a better look when inspecting older units. Not so that I can claim to conduct a thorough inspection of the exchanger but rather a means to possible locate cracks.
If you do this what type of camera/tool do you use?
Vince Santos
StepByStep Home Services LC
(734) 748-9584
Providing Home Inspection Services to Southeast Michigan
facebook
ITA Trained and Certified
Old 12/16/08, 2:55 PM
Andrew MacDonald's Avatar
Andrew MacDonald Andrew MacDonald is offline
Default Re: HVAC Tools
Vince,
I use this RIDGID See Snake.
http://www.amazon.com/gp/product/B000WTKC3O
Andrew MacDonald
MacDonaldPropertyInspections.com
InsightThermalDiagnostics.com
ITC/FLIR Certified Building Science Thermographer
ITC/FLIR Certified Level 1 Thermographer
Old 12/16/08, 4:38 PM
Jamie A. Stoulil's Avatar
Jamie A. Stoulil Jamie A. Stoulil is offline
I also use the Rigid Sea Snake but have found the head of it to be to large for some units. Overall will give you a good view, just remember it is difficult to inspect heat exchangers with out disassembly which we don't do... Happy inspecting..
Old 12/17/08, 9:42 PM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Since I am an HVAC Service Techand do lots of furnace inspections and wrote the article "Heat Exchanger Inspection Methods" thought I would comment on this. Rigid has come out with a newer inspection camera the MicroExplorer which has an internal sd disk to record the inspection and a USB port. They have also come out with a 9.5mm camera head that can be used on the MicroExplorer or the SeeSnake. Milwaukee has also come out with an inspection camera similar to Rigid. Testo 318-V has a smaller head just a little larger than a pencil eraser.
The premier camera is "The Inspector" by Shamrock Industries. It is a more expensive camera has a larger head. It's an infrared camera that uses only available light. Remote adjustable focus. And can record the inspection as a video on a sandisk.
Now each camera has its place. The screen size on each one is different. The Inspector of course has the largest screen and small details will are really blown up in detail on the tv screen.
Rigid MicroExplorer
Rigid See Snake Micro Inspection Camera
Rigid 9.5 mm Imager Head
Milwaukee M-Spector Digital Camera
Testo 318-V
Shamrock Industries "The Inspector" the world's first heat exchanger inspection camera
what to report on old hvac equipment bking Inspecting HVAC Systems 8 7/6/08 4:10 PM
Room size requirement for HVAC supply kweiss Inspecting HVAC Systems 3 6/9/07 6:58 PM
Access to Electrical Panel in Ontario by HVAC Contractors Nalliah Thayabharan Canadian Inspectors 10 5/21/07 3:01 PM
Condemned Furnaces Spark Safety Issues Gary Reecher Inspecting HVAC Systems 7 3/8/07 8:17 PM
