Just jerking your chain mines free cannot teach on this board what it took me 40 years to learn. I must be a slow learner?????
Just can not get away from Hvac did another IR scan today and the client complained about another room on the second story that was always cold and wanted me to scan the room. It took me no longer than it takes to enter the door to see the problem. Large bedroom on the NW corner of the home no wind breakers on the exterior and the supply duct was being fed with a six inch duct I could tell this by the size of the grill on the ceiling and confirmed by entering the attic. The take off from the plenum was a 9 inch trunk and had 3 drops being supplied I could have spit more air than was being discharged from the register. This home had been added on to on both levels and the upstairs two added on rooms was being fed from an upstairs furnace and the supply for the addition was tapped into the top of the plenum with no balancing damper installed. The new addition was robbing all of the air from the remaining section of the home. This was accomplished by a Hvac contractor. Grab the money and go. And how many times have I heard on this board refer to a HVAC contractor. The moral to this story is I wonder how many IR guys would have Scaned the room pointed out any deficiency noted with the camera and walked away???? Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging Last edited by cbottger; 1/28/09 at 11:24 PM.. |
Hi Charley....seems like the hardest thing is finding a GOOD HVAC man, one who is honest, knows the business, is reliable, and has the ability to talk to someone in layman's terms.....I finally found a GOOD HVAC man about a year ago....he has saved my clients thousands of dollars in unneeded parts, equipment, and man-hours doing the work.
I think the best one was about two months ago, two different licensed contractors here in the Valley told a friend of mine she needed a new condenser, no way around it....my HVAC man went there and found a $50.00 part solved the problem. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
I think we could even go as far to say some inspectors don't ever know what size headers are required for any given application and etc.... When I went to take an advanced HVAC course and the main Q's were about the A/C drain lines I knew there are a lot of home buyers in trouble..anyone can inspect?
Even worse the instructor spent over 20min with this inspector...I pulled my guys from the class and spent the day doing tourist things ( was @ NACHI Orlando convention) |
BTW Kirkland Wa use to be a very nice place the first girl I dated away from home lived in Kirkland Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
there are 7 large HVAC/R companies in the surrounding 6 counties ...with countless small HVAC shops ...... and only two companies I will recommend to my clients.
Quality contractors are few and far between. |
In my area, the best I can recommend is the better of a couple of "so, so" firms; the rest are crap!!!
Recently, at the beginning of the final deficiency inspection of a new $500,000+ home, when entering the mechanical room, I felt I had found a great new start-up firm. The ducts for the HP/AC appeared to be properly sized (the return trunk was larger than the supply trunk- good practice), it was an all metal duct system with vibration collars, there was duct liner to cut equipment sound, the ducts were sealed. But as I looked closer, the sealing was poor and no insulation was installed on ducts other than the duct liner to reduce sound!! Still looking for a GOOD HVAC firm!! Last edited by Brian A. MacNeish; 1/29/09 at 12:45 PM.. |
Well almost a 100 viewers from the time this post was started I would have to draw the conclusion that Hi's are still looking for cheep HVAC training
Maybe they are not even looking for cheap training but free.........something they have been conditioned to here!!
John Dee is a non-member guest and is in no way affiliated with InterNACHI or its members.
You guys are welcome to come and learn and trade and swap info.
at HvacrTalk.com anytime. |
| Watch this 2 minute video promo on HVAC training. | gromicko | Miscellaneous Discussion for Inspectors | 11 | 1/30/09 3:20 AM |
| HVAC Training | cbottger | Inspecting HVAC Systems | 36 | 11/25/08 7:50 PM |
| HVAC Training | bgromicko | Inspection Education & Training | 4 | 11/21/08 8:25 PM |
| 1-day HVAC training and marketing course in Greenville, South Carolina on October 21. | gromicko | Inspection Education & Training | 2 | 9/30/06 2:30 PM |
| 1-day HVAC training & marketing course with Kenny Hart & Nick Gromicko, SC, Oct. 21. | gromicko | Inspecting HVAC Systems | 0 | 9/20/06 10:18 AM |
