Old 2/3/09, 7:21 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Height of Furnace Flue
Would you recommend this flue be raised??
Old 2/3/09, 7:40 PM
Default Re: Height of Furnace Flue
Here's a guide:
Table of Type B-Vent Rooftop Clearance Requirements
The 1992 Vent Sizing Tables require that all Type B gas vents terminate above the roof with a listed cap or listed roof assembly in accordance with the manufacturer's instructions.
Vent caps 12" and smaller may terminate a distance above the roof if 8 feet or more away from a vertical surface as follows:
ROOF PITCH - rise/run in inchesMINIMUM HEIGHT*
Flat to 7/12 - 1.0 foot above the roof surface
7/12 to 8/12 - 1.5 feet above the roof surface
8/12 to 9/12 - 2.0 feet above the roof surface
9/12 to 10/12 - 2.5 feet above the roof surface
10/12 to 11/12 - 3.25 feet above the roof surface
11/12 to 12/12 - 4.0 feet above the roof surface
* Continues to 21/12 pitch at 8.0 feet
Vent caps larger than 12" must be located at least 2 feet above the highest point and 2 feet higher than any portion of the building within a horizontal distance of 10 feet.
From: http://www.inspect-ny.com/chimneys/B-Vent_Chimneys.htm
Larry Kage, CMI
231 929 3525
Old 2/3/09, 8:09 PM
Thanks!! Larry.
Old 2/3/09, 8:26 PM
Bob Elliott's Avatar
I am more concerned about the giant shadow of a robot I see in the picture,which is castings itself on to the roof image.
It appears to have a strange dome or bulb like contraption sticking from its head.
Almost pom pom like.
Old 2/3/09, 10:26 PM
That is my stocking cap 25 degrees at 4 PM!!
Old 2/3/09, 10:29 PM
I know. hahahahaahaha
How far from the vents was the flue?
Looks ok.
We had this issue last month. (caused a debate)
Old 2/3/09, 10:42 PM
Thanks!! Approx. 12 inches.
Old 2/3/09, 11:07 PM
Originally Posted by lkage View Post
Here's a guide:
Darn-o! I thought the 2/10 termination rule applied to all combustion vents for adequate draft reasons.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 2/3/09, 11:11 PM
Yeah, thats what I used to think.
I am still not 100 percent sure about if it should be 12 inch above that ridge in the picture.
Just looking at it makes you see down draft potential.
Old 2/3/09, 11:14 PM
Are those tables in the current IRC?
(303) 717-8940
Old 2/3/09, 11:18 PM
Good question.
I notice that you should check local codes and manufacturer guides.
Old 2/3/09, 11:23 PM
You know what?
Go here and download, the first PDF guys.
This is the best info on the subject and answers it.
http://www.hartandcooley.com/faq-bvent.htm
http://www.hartandcooley.com/vent/si...on%20guide.pdf
Old 2/3/09, 11:28 PM
Originally Posted by relliott View Post
You know what?
But if that's Hart & Cooley's guide, they're just one manufacturer. Might their information not apply everywhere?
(303) 717-8940
Old 2/3/09, 11:46 PM
Looks like a very good general information on B vents.
The diagram explains the general height rule very well.
Furnace Flue bkelly2 Inspection Question of the Day 70 12/1/08 8:39 AM
What's Inside A Chimney mcyr Inspecting HVAC Systems 14 9/17/08 6:11 PM
Gas Log Flue venting height. lagudo Inspecting HVAC Systems 34 4/7/06 1:42 AM
Oil Furnace Flue Clearance jfunderburk Inspecting HVAC Systems 3 2/28/06 7:17 PM
