Old 2/22/09, 7:05 PM
mbenerowski mbenerowski is offline
Default Help please Lincoln Oil ??? age output?
Hello, Im having problems with age and output ratings on a Lincoln oil forced air furnace
Model: LSWV
It has a AFG series oil burner made by beckett
Cheers and thanks in advance for anyone's help
Mark
Old 2/22/09, 7:08 PM
Stephen W. Stanczyk's Avatar
Default Re: Help please Lincoln Oil ??? age output?
Mark, We will need the serial number for what you are seeking.
Stephen Stanczyk
Old 2/22/09, 7:16 PM
Wayne B. Wilson's Avatar
If you don't have a serial number perhaps a nozzle size
there may be a number on the burner
Old 2/22/09, 10:12 PM
On the burner it says:
Beckett
Model AFG
Serial: 981209-54068
(this is on one sticker Left side of burner)
(on the other sticker just to the Right)
LB 2101A
Old 2/22/09, 10:56 PM
I can not find to much info for you
My guess it would be between 85.000 Btu to 140.000 Btu depending on the nozzle size
If i remember right these burners had 160 psi oil pumps on them
Date looks like 1998
Old 2/22/09, 11:23 PM
Thanks
Its a tough one.
I think ill make a call to Lincoln tomorrow.
Also got a heat pump problem want to take a crack at it
Grimsby Stove and Furnace ltd.
model : QH 824-1C
Serial 28203 138409
RLA 10.2/11.5
LRA 57/57
Old 2/23/09, 6:37 AM
2 ton
2003
Old 2/23/09, 9:24 AM
I think the tonnage is right but its very old and I think its production date is 1984. Making it 25 years old.
Old 2/23/09, 9:56 AM
Thanks Wayne.
I called the manufacutre and it has a F3 nozzle which gives 0.75-1.25 min / max
So 140000 x 0.75 = 105000 btu min
Should I report the lowest btu input range as its heating capacity?
Cheers
Mark
Old 2/23/09, 2:22 PM
your right 82
Old 2/23/09, 2:25 PM
Thanks Wayne.
Cheers
Mark
Mark i give it that range because that make of burner does run with a higher Pressure 0.75 would be more like 0.95 IMO
Strange history lesson cbottger Miscellaneous Discussion for Inspectors 1 3/18/08 2:52 PM
Light Bulbs- All Ya Wanna Know pabernathy Electrical Inspections 9 4/18/07 7:22 PM
