Old 12/30/09, 2:35 PM
mnicholet's Avatar
mnicholet mnicholet is offline
Please Note: mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default High efficiency furnace in attic
A high efficiency Nordyne furnace is installed in an attic. It is drawing combustion air from inside the attic as there is only one PVC pipe on the roof. Does this warrant repair by HVAC tech?
Find an InterNACHI certified Virginia Home Inspector (and anywhere else in North America)
Old 12/30/09, 5:03 PM
Bob Elliott's Avatar
Default Re: High efficiency furnace in attic
Not necessarily .
Should have both on the roof due to pressure differentials however.
They could have used a concentric vent and should have if to lazy to add another vent.
Old 12/30/09, 6:30 PM
staylor5's Avatar
staylor5 staylor5 is offline
it is perfectly fine to get combustion air from the attic as long as there is a PVC elbow and screen installed on the combustion air inlet.
Old 12/30/09, 7:14 PM
David P. Valley's Avatar
Do you have an image of the exhaust configuration at the penetration of the air handler cabinet?
Old 12/30/09, 8:45 PM
mnicholet's Avatar
Here are some pics
ID:	34085   high-efficiency-furnace-attic-pict0022-small-.jpg.JPG
Old 12/30/09, 9:06 PM
Originally Posted by mnicholet View Post
Here are some pics
Is there a drain pan ?
I see a condensation tube, but where does it go?
Unrelated ,it sure is easy to see the exhaust is on the north end of the roof, and those birds must be everywhere.
Old 12/30/09, 9:10 PM
Erol Kartal Erol Kartal is offline
Please Note: Erol Kartal is a non-member guest and is in no way affiliated with InterNACHI or its members.
Still would have been nice to run a supply through the roof. Goose neck PVC looks cool.
Old 12/30/09, 9:30 PM
mnicholet's Avatar
No drain pan, already called that out, thanks
condensate line goes into a DWV.
Old 12/31/09, 6:05 AM
Here are some pics
Thanks Mark...but I was curious and wanted to view the exhaust/combustion air penetration area at the right side of the cabinet.
Old 1/2/10, 2:38 PM
senwiinspection senwiinspection is offline
Please Note: senwiinspection is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hey Mark - the units have to be installed to meet code requirements AND manufactures installation requirements. I would check with the manufacturer to see if this was an allowed installation. See http://www.nordyne.com/web/ResLand.aspx for their site.
Renovating Your Basement for Livability mkyriacou Canadian Inspectors 0 10/22/09 12:45 PM
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing & Legal Issues for Inspectors 50 4/20/08 2:26 AM
Furnace in attic (High Efficient) jcordell Inspecting HVAC Systems 14 2/10/07 7:02 PM
Cat 1 Furnace in attic wdecker Inspecting HVAC Systems 2 6/14/06 2:28 AM
Proper Vent - High Eff. Gas Furnace rkuntz Inspecting HVAC Systems 8 1/13/06 11:18 PM
