Lets talk efficiency what through the eyes of a refrigeration person would be considered as high efficiency not the numbers listed by the MFG but what truly would be a reason for high efficiency in a residential A/C unit.
What would be your take on the pic below could it be a high efficiency and why or would it be low efficiency and why. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging Last edited by cbottger; 5/13/08 at 11:10 PM.. |
First off...
What does the manufacturer recommend for clearances? Where's the pad? Where's the Emergency shut-off? |
Second sentence nothing to do with efficiency Third sentence nothing to do with efficiency </IMG></IMG></IMG> Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
I really don't know about the other...it works or it doesn't. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
u guys are efficiently funny
"Neither the first, second, or thrid sentence have anything to do with efficiency" But seriously, How is one supposed to tell from that photo or any photo what the efficieny is? How do we even know if the plenum coil is properly matched? The current charge? The stated efficiency? etc, etc. |
Oh no...Not anohter of Charley B.'s . NOW CLASS
Go for it Charlie, teach these Cretans something. If that's possible. |
The disconnect was above just out of the pic The unit is setting on concrete not a heat pump not required to be raised. Yes the unit was a little close to the exterior wall had a hard time reading the data plate.If it had been moved out any further would of been blocking the sidewalk that traveled back under the raised deck. Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
In all seriousness besides the seer rating , the good tech will see if the size of the unit is matched properly to the space it must cool.
To small and it will over work. Too large and it will burn the compresser with to many starts and stops. Is the ducting sealed properly.? Hows the house insulation.? Are thereturns placed in proper locations and are they balanced to the vents(output) It is a lot of things. Me I just turn it on. lol |
| Liability question | jcahill | Legislation, Licensing & Legal Issues for Inspectors | 30 | 8/24/08 5:10 PM |
| How high do collar ties need to be? | Nathan W. Swilling | Structural Inspections | 12 | 1/9/08 12:41 AM |
| High Efficiency venting????? | Matt Lewis | Inspecting HVAC Systems | 8 | 11/10/07 12:31 AM |
| High Efficiency furnace | rdean | General Inspection Discussion | 8 | 1/20/07 8:48 PM |
