Old 10/6/09, 10:00 PM
Joshua L. Frederick Joshua L. Frederick is offline
Default High efficiency vent clearance from ground
What is the minimum clearance from the ground for an area of the country that gets snow (Northwest Ohio)? I know this can't be right, but I was hoping someone had a picture or link to verify.
Thanks in advance!
high-efficiency-vent-clearance-ground-903-north-lane-defiance-008.jpg   high-efficiency-vent-clearance-ground-903-north-lane-defiance-009.jpg
Find an InterNACHI certified California Home Inspector (and anywhere else in North America)
Old 10/6/09, 11:11 PM
Bob Elliott's Avatar
Default Re: High efficiency vent clearance from ground
Looking at a PDF for one model it states 12 inch ground clearance.
How come I do not see the exhaust in your picture as they are normally 18 inches apart.?
Old 10/6/09, 11:38 PM
David A. Andersen's Avatar
That pipe doesn't look big enough from here.
BPI# 5015804
Old 10/7/09, 5:46 AM
gkay gkay is offline
Please Note: gkay is a non-member guest and is in no way affiliated with InterNACHI or its members.
Typical manufacturers' instructions state exahaust and or intake must terminate at least 12 inches above grade or anticipated snow levels. Single pipe installations are acceptable with some furnace models but require a combustion air supply. It looks like 2 inch venting which is acceptable in some installations depending on total length, we are using 636 venting to replace PVC shedule 40 pipe.
Old 10/7/09, 6:44 AM
The intake is apparantly in the crawlspace, which I wasn't able to enter or verify.
Old 10/7/09, 8:14 AM
Agreed...
Larry Kage, CMI
231 929 3525
Old 10/7/09, 12:01 PM
Here is a good informative diagram.
Old 10/7/09, 10:23 PM
James E. Braun, CMI's Avatar
So then it is 12" above anticipated snow level, correct?
Old 10/8/09, 9:22 AM
Yes.
Larry Kage, CMI
231 929 3525
Old 10/12/09, 8:58 PM
Also need to look carefully at intake pipes (where used). If too close to the ground it can suck up leaves and other light material. That material will generally get caught at the screen right at the furnace but can eventually reduce air flow to the point that the furnace will trip on flame roll-out.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
High Efficiency venting????? Matt Lewis Inspecting HVAC Systems 8 11/9/07 11:31 PM
High Efficiency furnace rdean General Inspection Discussion 8 1/20/07 7:48 PM
Proper Vent - High Eff. Gas Furnace rkuntz Inspecting HVAC Systems 10 1/13/06 10:18 PM
